Badly Damaged Veneer - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-12-2012, 06:55 AM   #1
Caution! Girl working
Badly damaged veneer
Hello, all,
This is a photo of my porch, which is concrete block with brick veneer. The block underneath is visible from inside the basement and is in perfect condition, so this damage seems to be limited to the veneer. I won't know for sure whether the structure is sound until I get the veneer off but I believe it's in good shape underneath.
The prior owner 'fixed' the cracks by filling them with tubes and tubes of caulk then covering with paint. Of course, he never fixed the water source that was causing the problem, and the water then got trapped inside so the veneer is basically crumbling from the inside out now.
I've corrected the water source and I'm wondering
1) what is the best way to remove the broken veneer?
2) The porch is not really visible to any neighbors, so can I just prime and paint the block or do I need to cover it with vinyl siding or pressure treated panels or something?
Thank you!
ADaniLion is offline   Reply With Quote
Old 06-12-2012, 08:15 AM   #2
DIY staff
Rewards Points: 7,174
A picture from farther back is needed---what is above that wall?
I would think that removing the bad brick would be the starting point---but what is that brick supporting above?
Old 06-12-2012, 11:39 AM   #3
Architect
Rewards Points: 150
I am a masonry restoration specialist.
You got a doosey there.
I believe you are right that tearing off the veneer and relaying it is the only option. Just start from the top down. There should have been tie backs of some sort installed in that wall since no row lock course is visible. These were probably steel and I am sure are gone. You will have to install new retrofit tie backs, screwed into the block (the mortar joints are the best location). I would use galvanized.
Be sure to install weep holes this time at the bottom to discharge any condensation that builds up inside the wall.
jcarlilesiu is offline   Reply With Quote
Old 06-12-2012, 02:44 PM   #4
Thank you for your replies! There is nothing on top - just a slab that's around 5 ft. square...a tiny porch off of the kitchen.
I had forgotten about the weep holes...the rest of the house doesn't have them, either, so I occasionally get minor condensation along some of the exterior basement walls. Never puddles and there's not much I can do about it (is there?).
For the porch, can you advise, in general, on how weeping holes are supposed to be done so I have some idea when I call a local mason? I hate being completely clueless when getting estimates lol!
Old 06-12-2012, 03:58 PM   #5
Architect
Rewards Points: 150
Veneer walls typically contain a space between the back of the veneer and the structural substrate material. This space allows condensation caused by the cool wall to form at the exterior side, in the air space. As this water gathers, and drains to the bottom of this cavity, it needs a way to discharge.
There are alot of ways to allow this water out. You can simply exclude a head joint every so often from being mortar filled and just leave it open. Some people prefer a cotton wick that sticks out of the wall and penetrates into the cavity space. This is preferred to some as they think that it helps to "soak" up any water and wick it to the exterior. One last option is a product that is made that takes the place of the head joint and is corrugated that allows water to expel.
http://www.nachi.org/forum/f16/brick...83/index4.html
http://img.tfd.com/architecture/f0619-02.png
The Following 2 Users Say Thank You to jcarlilesiu For This Useful Post:
ADaniLion (06-13-2012), jomama45 (06-12-2012)
Old 06-12-2012, 07:58 PM   #6
DIY staff
Excellent explanation----
Old 06-12-2012, 10:00 PM   #7
Concrete & Masonry
Rewards Points: 636
Hello, all,
Saw cutting and "toothing" the veneer is the best approach IMHO. It takes some time, but it is certainly worth it.
Thank you!
Simply source a brick that's close in size & texture, and paint the repair to match the existing. Painted brick is a relatively easy repair, all things considered.......
jomama45 is online now   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
Old 06-13-2012, 07:52 AM   #8
Thank you! Leaving mortar out here and there seems like the easiest way to allow enough air flow and water release. I really, really appreciate your help!!
Peel and Stick Veneer and Contact Cement GreggG Kitchen & Bath Remodeling 6 02-23-2015 05:30 PM
What to do where cultured stone veneer meets grass shleppy Landscaping & Lawn Care 5 09-03-2014 06:39 PM
Stone Veneer (ledgestone) fireplace remodel questions Augy Remodeling 11 09-17-2013 04:57 PM
Fireplace Brick Veneer TV Mounting RICKM15752 Building & Construction 3 12-14-2010 04:03 PM
Badly termite damaged wall phenix76 Building & Construction 3 01-14-2009 11:12 PM
