Attaching Window Boxes To Marble - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-08-2013, 07:58 PM   #1
Attaching Window Boxes to Marble
Hey all,
I live in a 1920's rowhome in Baltimore and have a 2.5 inch thick slab of marble on the front of my house (over top of structural brick) underneath the marble window sill. The window is 62".
I'd like to attach a wooden planter to the front of the house. What's the best way to go about this? I may be able to make it wider and move it a little higher to catch the brick on the sides, but I think I'll need a center support which would need to sink into the marble.
Thanks in advance,
-Matt
standmatt is offline   Reply With Quote
Old 04-08-2013, 08:33 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,760
I would drill into the mortar on the brick as that will be easier to conceal in the future and repair.
Pad that area out a bit with Azek or other PVC wood.
Attach you box to the PVC spacers.
Old 04-08-2013, 09:54 PM   #3
So if I widened the box out another 3 inches on each side, I could catch a few grout lines with Tapcons...would this be enough to hold the box though? If not, should I use an epoxy anchor instead?
We're talking close to 400lbs fully loaded with wet dirt (based on 120lbs/ft^3)
Also, for the spacers, are you saying just something like 1/2 inch blocks to hold it off the house?
-Matt
Old 04-09-2013, 03:42 AM   #4
Rewards Points: 4,656
you posted ' i live ' - if you rent, you can't legally attach anything,,, if you own, you can here are some other solutions:
1 - lightest solution - plastic flowers & hold up w/boogers ;
2 - heavy - fabricate wrought iron shelf & brackets - attach to
grout linesw/shielded lags ;
3 - heavier - core drill the sill & epoxy s/s threaded rod in addn to # 2 - boogers optional;
4 - heaviest - thru bolt & secure on interior w/3/8" steel plate
Old 04-09-2013, 07:43 AM   #5
Sorry for the confusion, I do own the place.
The epoxy method sounds good to me, only because I worry about cracking the brick/marble with lag shields and its a plaster wall inside and I really don't want to rip that down to thru-bolt.
Any recommendations on epoxy? I think they sell this one at the local big box store http://www.strongtie.com/products/an...set/index.html
Old 04-10-2013, 09:04 PM   #6
simpson's a good mtl,,, how're you going to get the mtl into the hole ? cost of the dual cartridge epoxy gun may be more than its worth to own,,, the BIGGER problem is coring the piece,,, we own a weka 3speed hand-held core drill so its no trouble,,, may have to have this done for you by a conc cutters/corers OR you might find a commercial plumber/steamfitter.
using a rotary hammer / hammer drill wouldn't be my choice either
Old 04-10-2013, 10:57 PM   #7
It looks like they sell some now that's compatible with a standard caulk gun, but I'll have to look more closely. (http://www.homedepot.com/p/Simpson-S...3#.UWY0VBkkX-Y)
Also, I figure I can just mount it a little higher than I was originally planning on and catch the bricks on either side of the sill...that way I can avoid drilling the marble at all.
Out of curiosity, whats the difference between a core drill and a regular drill? I've drilled a smaller hole in stone tile with a core drill bit attached to a standard (non hammer) cordless drill.
Old 04-11-2013, 06:35 AM   #8
not much in the drill motors - both have them & both motors are air-cooled,,, a core drill [ http://www.ohiopowertool.com/p-1095-...l-4244017.aspx ] will use a segmented diamond-tipped bit [ http://www.contractorsdirect.com/Con...-Wet-Core-Bits ] that is water fed from the inside of the bit thereby flushing debris from the hole & cooling the bit,,, core bits accomplish their goal by eroding the material they're drilling,,, regular steel bits just drill & scrape away material.
drill the mortar NOT the bricks,,, either a light hammer drill ( bosch bulldog class ) OR heavier regular household twist drill - hope this helps !
Covering basement window mike-ss1 Building & Construction 6 03-26-2013 02:18 PM
how to deal with a window in a shower MLMIB Kitchen & Bath Remodeling 9 09-12-2012 08:41 AM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
