Attaching Thin Stone Veneer To Plaster Walls - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 01-06-2013, 01:29 PM   #1
Attaching Thin Stone Veneer to Plaster Walls
I'm finishing off a wood stove install and would like to build an alcove next to the fireplace in which I can store wood. I removed some cabinets that were previously there... you can see the glue residue and old blue paint to the right of the fireplace.
I ordered matching natural thin stone veneer and now I need to figure out the best way to attach it to the wall. The house was built in 1957 and as best I can tell, the walls are sheetrock covered with metal lathe and then plaster on top. Here are two pics of the walls... the first is inside a closet where a piece of trim is missing so you can see the exposed edge. The second is a small area I chipped away adjacent to the fireplace where I intend to install the stone.
I've read all over the place and it sounds like there are two generally accepted methods for interior install... first is to screw wire lathe to the wall, scratch coat with mortar and then mortar stones to wall. The other is to use thinset to attach stones directly to hardi backer. Both of these methods are approved by the manufacturer of the stone.
I haven't been able to find any recommendations on how to attach stone veneer to a plaster wall. I could remove the plaster, put up hardibacker and do thinset, but that would be messy and time consuming. I could do the metal lathe/mortar but then the wall would consist of sheetrock, lathe, plaster, lathe, mortar, stone, which seems like a lot.
Any other options or input?
jeffesonm is offline   Reply With Quote
Old 01-07-2013, 09:59 AM   #2
Rewards Points: 1,230
If you can remove the paint, you should be OK straight to the plaster, unless it is gypsum plaster, which it probably is. 1/4" hardie screwed to existing is your best bet.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 01-07-2013, 07:53 PM   #3
Rewards Points: 4,534
had a similar situation in an old mountain cabin - we lined the area w/cedar rough cut side visible,,, yes, it scarred when the wood was stacked but we liked the distressed look & it fit the decor - only 1/2 day's work, too
Refinishing room-width cuts of plaster walls: will it work? Minich Drywall & Plaster 9 07-19-2011 09:28 PM
Prepping plaster walls for painting phantasm72 Painting 11 07-03-2011 06:34 AM
Plaster Walls? I dont know? chsitko Drywall & Plaster 4 08-28-2010 06:30 PM
blueboard + veneer plaster Tonglebeak Drywall & Plaster 5 02-28-2010 09:41 PM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 06:33 PM
