Attaching A Rail To Cultured Stone - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-07-2013, 11:46 PM   #1
attaching a rail to cultured stone
every search i've tried takes me to installation of the cultured stone itself, not about how to attach items to cultured stone that already is installed...
i'm trying to install a vinyl handrail to an existing post that has the cultured stone already installed... the supplied screws that came with it don't seem to work... it simply screws into the veneer and makes the hole wider... there's no grab... and now i've got holes in there that won't hold the screw and that's exactly where i need to put it...
any ideas? are there specialized screws for cultured stone?
thanks.
danxp is offline   Reply With Quote
Old 04-08-2013, 10:22 AM   #2
Rewards Points: 12,822
Got a picture?
Just attching to the fake stones not going to cut it.
Going to need long enough screws to reach what's behind it.
Use stainless or ceramic coated screws. the longer the better.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
danxp (04-08-2013)
Old 04-08-2013, 10:45 AM   #3
Rewards Points: 4,450
isn't ' cultured stone ' mostly cement, water, & fine aggregate ? if so, there's nothing to which your screws can ' grab ',,, even if they did, 1 good railing yank or load may possibly cause it to dislodge w/resultant injuries,,, joe's right, you gotta thru-bolt to something strong enough to hold & resist possible force,,, downside is longer thru-bolts will probably magnify applied force loads [ think of a lever & fulcrum ]
you might try adding lead or vinyl shields but i doubt they'll be successful either
The Following User Says Thank You to stadry For This Useful Post:
danxp (04-08-2013)
Old 04-08-2013, 11:13 AM   #4
thanks for the replies all... looks like it will require at least 3 inch screws to get to what's behind the cultured stone... only problem is i think it may be the post hardware... ugh...
Cultured Stone fireplace lindyloo Concrete, Stone & Masonry 3 10-31-2012 05:32 PM
cultured stone over real stone sulevia Building & Construction 3 09-23-2010 12:23 AM
J-Weep / Flashing for exterior cultured stone veneer wall. Spud Building & Construction 18 08-31-2009 10:44 PM
Cultured stone issues jdrolls Building & Construction 1 06-14-2009 11:56 PM
