Attaching Dock Cleat To A Concrete Seawall & Drill Vs Hammerdrill - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 01-03-2014, 10:54 PM   #1
Rewards Points: 271
Smile
Attaching dock cleat to a concrete seawall & drill vs hammerdrill
I need to install a boat or marine cleat to a seawall. Some are on wood dock but I need one on the concrete seawall. I was thinking about using Tapcons, get a masonary bit and use the electric drill.
I mentioned to a buddy and he said get a hammer drill. I have a decent home electric and also a cordless drill. The electric drill would probably be okay for cinderblock but the seawall looks like poured concrete.
Any suggestions? Also should I get like a glue/cement for the hole to make sure the screw/bolt stays tight even with a Tapcon? Thanks and sorry for the dumb questions.
FrankL is offline   Reply With Quote
Old 01-03-2014, 11:04 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 546
I would use a hammer drill- and I'd also use an anchor stronger than a tapcon- such as these
http://www.fastenersplus.com/product...FdE-Mgodp04Amw
I use these in concrete ceilings to hang pipe racks and pipe hangers on commercial jobs
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
FrankL (01-03-2014), Msradell (01-04-2014)
Old 01-04-2014, 04:24 AM   #3
Rewards Points: 13,446
And for a hole big enough for an anchor like that I'd be using A SDS style hammer drill.
A regular drill would be about useless.
Old 01-04-2014, 07:08 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,006
Ayuh,.... A hammer-drill drills holes in concrete,...
A regular drill will just burn up the bit,...
Old 01-04-2014, 07:12 AM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,020
SDS as well.
Don't try this with a standard hammer drill or worse yet...standard drill. Your wrists will hate you.
Old 01-04-2014, 07:43 AM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 288
You may want to think about fasteners that will not rust away.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 01-04-2014, 03:04 PM   #7
Rewards Points: 3,518
I'd use a wedge anchor,and be sure you don't wallow out the hole,just in case you do have some epoxy on hand.
Canarywood1 is offline   Reply With Quote
Old 01-07-2014, 04:41 AM   #8
Rewards Points: 4,578
'sds' just refers to the method of attaching the drill bit securely into the drill's chuck,,, some other drill bits use either tapered bits, spline, improved sds, jacobs, hexagon, etc,,, the actual drills are usually selected by hole size hole they're capable of drilling in conc - 1", 1 1/2", 2", etc.
rent a 1 1/2" hammer/drill ( aka rotary hammer ) & some 1/2" bits which usually drill 5/8" holes in cured conc,,, lead anchors are my pick HOWEVER you don't post anticipated cleat load,,, im-n-s-h-fo, IF a hole 'wallows' out ( drill bit drifts - hits steel - etc ), 1 is better advised to move hole OR patch & redrill - not try to repair w/epoxies,,, its an acceptable method for someone who knows his work but not for 1 who doesn't,,, we can assume the latter group includes you, yes ?
nevertheless, best wishes !
Old 01-07-2014, 12:10 PM   #9
Pro
Rewards Points: 91
A tapcon is not the fastener to keep the cleat there. Use an expanding anchor - I use the hilti stainless ones.
Robert Cram
Robert Cram Construction
CarpenterSFO is offline   Reply With Quote
Fix Drill Holes in Concrete Foundation Wall jdusling Building & Construction 8 08-26-2011 10:31 AM
Attaching 4x4 posts to a concrete porch. dweagle Building & Construction 6 04-01-2010 06:41 PM
Attaching wood srtips to concrete wall DIY4EVER Building & Construction 11 07-21-2007 10:10 PM
How to drill 6-8" hole in reinforced concrete? Jemo Remodeling 2 02-26-2007 01:36 PM
How do you measure poured concrete PSI? head_dunce Building & Construction 18 02-25-2007 08:58 PM
