Asphalt Oil Based Product Hardening Needed - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-08-2012, 10:02 AM   #1
asphalt oil based product hardening needed
I have a jetcoat foundation coating product which is pliable after
cured, the ingredients listed are petroleum asphalt , & mineral
spirits (cas no. 8052-4 64742-88-7 ), does anyone know of a way to
harden product during application such a a activator-catalyst-solvent
hardener product to mix with or a home receipt per 5 gallon pail,
thanks
nfl2k2 is offline   Reply With Quote
Old 04-08-2012, 11:49 AM   #2
Rewards Points: 14,278
Why do you need it to turn hard?
If it's hard it's brittle and may crack as soil conditions change.
Old 04-11-2012, 01:30 PM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
Nobody tries to turn asphalt hard. Usually the other way around. Chemists add plasticizers to it to keep it from getting brittle. It would help to know what you are trying to accomplish.
Torch Down Instructions Needed - DIY MikeinBurien Roofing/Siding 86 10-07-2012 11:21 AM
Latex over alkyd primer TVC15 Painting 15 08-14-2010 11:42 PM
oil vs water poly batwoman Flooring 6 09-30-2008 10:00 PM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Asphalt based Roofers Pride ALL weather roof patch Traba Roofing/Siding 1 03-29-2008 06:34 PM
