Asphalt Driveway Questions - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-29-2012, 05:54 PM   #1
Cruising into the sunset
JulieMor's Avatar
Rewards Points: 518
We're getting ready to get some prices to replace our existing asphalt driveway. I drew up a plan and want to put specs, requirements, etc on the plan. I've attached the plan and would appreciate some input about what else I should add, subtract or change on the plan.
Thank you!
JulieMor is offline   Reply With Quote
Old 04-29-2012, 08:04 PM   #2
Msradell's Avatar
Rewards Points: 84
You probably want to add what size aggregate is to be used in the asphalt. You may also want to discuss compaction of both the gravel and the asphalt. You should be able to find specifications for both of these on highway department websites.
Msradell is offline   Reply With Quote
Asphalt Driveway erb170 Building & Construction 7 10-24-2011 06:22 PM
seal/caulk garage concrete floor to asphalt driveway? tigerbalm2424 Building & Construction 1 02-14-2011 08:38 PM
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 09:14 PM
Driveway Gate Construction Questions KP Texan Building & Construction 3 07-30-2009 09:45 PM
driveway, concrete or asphalt? johnny331 Building & Construction 2 06-19-2007 11:03 PM
