-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   asphalt drive sealers ? (http://www.diychatroom.com/f105/asphalt-drive-sealers-145927/)
Fix'n it 06-04-2012 10:20 AM
my driveway has never been sealed. its 5y/o, and looks in pretty good condition. i was looking at the sealers at HD etc. i have "heard" that those are not that good, but i "hear" a lot of things (if you know what i mean).
so i thought i would ask you guys. thanx
TarheelTerp 06-04-2012 12:01 PM
They're better than what the Gypsy's who come around will do for you.
Read the directions and then follow the directions.
You'll be OK.
Bondo 06-04-2012 08:49 PM
You'll be OK.
Ayuh,... It's the same sealer the Gypsy's use,...
They just cut their's by 1/2, with water....
Sealing is kinda a waste of time 'n money, unless yer seein' Cracking...
'n if yer gettin' Crackin',... Use the sand added sealer, it's thicker with more body...
Fix'n it 06-05-2012 10:22 AM
yeah, i am trying to avoid the gypsy's. i am going to call a pro in the area to get an estimate.
yeah, there is a little cracking. its not bad, but there is a little. i'l get pics later.
Fix'n it 06-05-2012 08:54 PM
3 Attachment(s)
first pic is the crack. 2nd pic is the length, and i have about 15" behind me. i have yet to measure it. i am guessing about 100' long.
3rd, you can see the berries that a tree is dropping on my drive :mad:. and my trucks. the silver is my daily. the black is my HOT ROD.
Fix'n it 09-28-2012 10:32 AM
i finally did it. pics later.
