Ash Trap Draft - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-24-2013, 09:31 PM   #1
Rewards Points: 29
Ash Trap Draft
I'm wondering what I should do with the ash trap in my fireplace. The house is built on a slab and the lower level has a fireplace with an ash trap. The door is old and rusty. The clean out door is on the exterior of the chimney and is mostly buried under 50 years of top soil and pachysandra. The problem I'm having is a cold draft blowing through.
Should I fix the ash trap doors or fill with cement to seal off the draft? Something tells me the ash trap isn't safe to use anyway. The hole is about three or four feet deep.
Door
Hole without door
Big Ash Hole
Peter D. is offline   Reply With Quote
Old 02-25-2013, 04:12 PM   #2
Concrete & Masonry
Rewards Points: 468
The ash dump door/frame should be the same size as one 4.5" x 9" firebrick, which is exactly what I would recommend replacing it with. Fill the bottom of the hole with solid rubble/old brick/etc... and place the firebrick flush on top of it........
jomama45 is offline   Reply With Quote
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 12:46 PM
PVC trap adapter on galvanized trap? dougan Plumbing 2 10-05-2012 07:16 AM
Trane XR90 - Condensate Drane Trap JDWorks HVAC 16 02-07-2012 08:59 PM
kitchen wall drain outlet higher than trap arm Druidia Plumbing 24 10-13-2011 01:39 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 07:14 PM
