Apron Corners Loose - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-22-2013, 03:42 PM   #1
Rewards Points: 518
Apron corners loose
Both corners of my driveway have become bouncy as some of the packing has washed away due to unfinished landscape. The rest of the apron/driveway seems solid and shows no signs of voids.
The concrete guys who did the pour checked it out and said the rebar is still holding find and have offered to come shove some additional concrete from a left over job as a filler if I dig out around the edges. Any suggestions if this will work or any other options?
I don't particularly want to go the mud jacking route since it is only a 2 year old slab and don't want patch holes all over if I can avoid it.
n0c7 is offline   Reply With Quote
Old 04-22-2013, 06:50 PM   #2
Rewards Points: 4,534
if you trusted him enough to place the driveway, let him fix it,,, why even consider ' mud jacking ' ? ? ? using incorrect method / materials will never resolve an issue - only exacerbate it + make it more expensive when 1 finally fixes it correctly !
Old 04-22-2013, 10:18 PM   #3
Rewards Points: 518
Was already done when I bought the house.
How to you skim for *tight* corners mobiledynamics Drywall & Plaster 3 03-13-2012 07:32 PM
recommend a book nvr2low Drywall & Plaster 9 12-22-2011 12:37 AM
Filling the inside corners of my tile shower ryan5068 Flooring 11 07-26-2010 01:53 AM
typical room dimensions + corners? cwm9 Drywall & Plaster 3 03-19-2010 12:54 AM
A few questions on skim coating, matching drywall texture, and corners Scott99999 Drywall & Plaster 9 12-08-2009 05:17 AM
