Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-03-2012, 05:32 PM   #1
Quackerjack's Avatar
Apply Wire Mesh For This Parging Patch Job?
Hi, I have some parging to do on my house and this is the biggest bad spot I have. There is a missing patch of wire mesh and the material behind it is some kind of asphalt shingle-like fake brick stuff which moves a bit when I press against it.
Should I just install a piece of wire mesh in there before applying a layer of self-bonding cement? If so, how should I attach the wire? Or is there a better alternative?
Photo on 2012-12-03 at 5.11 PM by Whippersnapper12, on Flickr
Quackerjack is offline   Reply With Quote
Old 12-03-2012, 09:04 PM   #2
Going by the rust on your lath, you should probably just tear it all off and start over. At the least, you need to cut it back to non rusted lath.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is online now   Reply With Quote
The Following User Says Thank You to Tscarborough For This Useful Post:
Quackerjack (12-04-2012)
Old 12-03-2012, 10:22 PM   #3
Ack! Say it isn't so ...
Old 12-03-2012, 10:40 PM   #4
funfool's Avatar
At least cut more of the concrete back to expose the lathe.
Like any patch job, even drywall, you need to spread it out and blend it in to make it disappear,
I would use a 4" grinder and a diamond wheel on it to cut back the concrete to where the wire is solid. Cut with grinder and break out with hammer.
Seems like all the rust would be right where the opening is and where water got in.
Then attach new wire to solid wire, just because old wire turned brown, I would not say is unusable for a patch job.
Either way you want to open it up to bury new wire and not just nail it on surface over old hole.
If it was easy, we would not call it work!
funfool is offline   Reply With Quote
The Following User Says Thank You to funfool For This Useful Post:
Wire mesh over polystyrene JAS135 Building & Construction 1 12-02-2012 09:18 PM
Welded Wire Mesh & Fiber Mesh Jim Anton Concrete, Stone & Masonry 4 05-01-2012 05:22 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 02:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 10:00 PM
