Apply More Stain AFTER Concrete Has Been Sealed? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-02-2012, 06:03 PM   #1
Rewards Points: 18
Apply more stain AFTER concrete has been sealed?
Hello,
I have had an interior concrete floor professionally stained and polished, and then a Topguard Sealer applied. The problem is, the final stain job did not look that great, but we didn't get to see it before the company put on the sealer. Is there any way to apply a new coat of stain at this point? We are only using water based Smiths stains.
Thank you.
rumiat is offline   Reply With Quote
Old 07-02-2012, 06:21 PM   #2
Too Short? Cut it Again!
The stain will not penetrate the sealer and if it did it probably would only in thin places.
Old 07-02-2012, 07:08 PM   #3
Rewards Points: 3,740
Originally Posted by rumiat View Post
Hello,
Thank you.
The sealer will have to be removed before you can add stain.
Canarywood1 is offline   Reply With Quote
Old 07-02-2012, 09:05 PM   #4
Rewards Points: 18
Thanks. What is the process of removing sealer - can you grind it off, or is it a chemical process? And do you know how successful it might be? I know the sealer is meant to penetrate, and wonder if it might remain in some spots, making the re-stain look splotchy.
Old 07-03-2012, 01:24 PM   #5
http://wiki.answers.com/Q/What_can_y...r_off_concrete
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
How to seal below concrete board sealed with RedGard Dshamgar Building & Construction 4 08-14-2012 09:18 AM
Stain a large concrete patio (or paint?) ArizonaJay Painting 1 11-14-2010 01:02 PM
Oil stain on colored concrete Fleener Building & Construction 1 12-22-2009 11:39 PM
Concrete Solid Stain vs Semi Transparent hgiljr Flooring 5 05-06-2008 05:00 PM
