Anyone Install Their Own Egress? - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-26-2012, 03:12 PM   #1
John @ OHFS's Avatar
Anyone install their own Egress?
Thinking about getting some engineering plans made up to add a full sized door egress out from our basement. Has anyone ever done this before? What parts are DIY-able?
John @ OHFS is offline   Reply With Quote
Old 06-26-2012, 07:45 PM   #2
MarginallyQualified
Rewards Points: 2,464
Once the trench is dug and the retaining wall/stairs are formed/poured and the steel lintel is installed.. installing a door becomes basic carpentering
Old 06-26-2012, 08:07 PM   #3
DIY staff
Rewards Points: 7,174
I had a handicap ramp cut into an existing basement---it is all fairly advanced concrete work and excavating----the only thing I was able to do was open the finished basement wall--then wait till they finished--so I could add the entrance door and restore the basement finish work.
Old 06-27-2012, 07:45 AM   #4
I was thinking about renting an excavator myself and digging the trench. I'd have a concrete company pour the footers, wall and cut the hole. TBD, I guess.
Old 06-27-2012, 09:24 AM   #5
Bill Kearney
Rewards Points: 1,174
First step is call your local Miss Utility number to find out if anything is buried anywhere near where you want to dig. You DO NOT want surprises. Gas, water, sewer, phone, electric, etc. This is true whether you dig, or have someone else do it. The service is often free.
As for DIY, I suppose it depends on how deep you need to go, and what kind of soil conditions are present. For a 4 foot well it might be a DIY task, but any deeper and it gets a lot riskier. You don't want to have the backhoe tip over, or the soil to collapse under it. That and the condition of the foundation needs to be considered.
What's your plan for all that excavated dirt? When I carved out a portion of our yard for a hot tub patio I neglected to plan for the volume of dirt that was in there. It was rough paying the landfill to throw DIRT away. Then I found a couple of local construction sites that would let me dump it as clean fill. So be sure you've got a place for the dirt before you start digging.
wkearney99 is offline   Reply With Quote
Old 06-27-2012, 12:39 PM   #6
All good points.
1. The house is new construction and was built in 2010. The foundation is solid poured concrete.
2. The excavation would depend upon the drawings from an engineer and code requirements for footer depth. I have a good amount of land and can easily find a place for all that dirt.
Old 06-27-2012, 01:08 PM   #7
We did a whole post about this egress option on our blog a while ago...
Old 06-27-2012, 03:03 PM   #8
Rewards Points: 13,694
Not really a great DIY job.
You do know it's possible to buy premade stair wells right?
Far less chance of them leaking if there all one piece.
Egress Window Recommendations jhakkim Building & Construction 4 03-08-2012 09:05 AM
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 10:00 AM
Aprilaire 560 Install Questions MisterTFM HVAC 4 12-15-2011 12:35 PM
Help with new construction window install pac127 Windows and Doors 1 09-26-2011 08:36 AM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 08:49 PM
