Any Way To Patch A Concrete Block When Wet - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-03-2012, 04:43 PM   #1
Rewards Points: 51
any way to patch a concrete block when wet
Is there anyway to patch a block that stays wet
joelowrider is offline   Reply With Quote
Old 03-03-2012, 05:29 PM   #2
Rewards Points: 13,270
Not even close to enough info.
Try again.
Old 03-03-2012, 06:01 PM   #3
concretemasonry's Avatar
Rewards Points: 2,578
Are you trying to patch a crack/joint or just coat the surface of the wall.
Dick
concretemasonry is offline   Reply With Quote
Old 03-03-2012, 06:01 PM   #4
Too Short? Cut it Again!
Why is it staying wet. Not a good sign.
Old 03-03-2012, 06:45 PM   #5
Rewards Points: 51
It is a block wall for a pond I have a hole about 2 inchs wide for an over flow but it is allways pouring out I am going to do another drain on the other side about 3 in,chs higher so I need to plug this hole
Old 03-03-2012, 07:19 PM   #6
So you answered your own question?
Old 03-03-2012, 07:50 PM   #7
Rewards Points: 51
No its not awnsered I have no clue what to plug it with
Old 03-03-2012, 08:10 PM   #8
Dike
Dike hydraulic cement, I used to sell it when I worked in the hardware store. Can’t find a listing for Dike. The link below is for Quickrete, I don’t have any experience with Quickrete band. The Dike would work on flowing water.
http://www.quikrete.com/productlines/HydraulicWaterStopCementPro.asp
Writer’s information is for discussion purpose only and should be confirmed by an independent source.
Hardway is offline   Reply With Quote
Old 03-03-2012, 08:55 PM   #9
You can waste money plugging it. But you need to determine what it is and why the wet and soggy block.
I use products from Abatron all the time.
Water. Gravity. Physics. Against the best products on the planet. Water will win brother. You have to source what it causing your block to fill with water. Or if you seal and fix it, the one next to it will fill next.
If you do not address the why your block is filling with water, and you seal it off so so it cannot harbor water? The water is just going to find itself to blocks nearby and cause you nightmares beyond those you already have.
Water is heavy and seeks low points. Cannot help it. Clogged gutters, bad grading and drainage could be causing that block to fill.
Old 03-03-2012, 09:04 PM   #10
Did you read the OPs post?
"It is a block wall for a pond I have a hole about 2 inchs wide for an over flow but it is allways pouring out I am going to do another drain on the other side about 3 in,chs higher so I need to plug this hole"
Old 03-03-2012, 11:02 PM   #11
Concrete & Masonry
Rewards Points: 526
You need a fast setting hydraulic cement, a professional grade like this would work best:
http://www.euclidchemical.com/elit/masonbrch.pdf
(Go to the bottom of the last page and look for the "Dam-It)
You typically want to mix it relatively quickly and create a ball of it on your hand (you really need to wear gloves with this stuff as it's very caustic) and force it into the hole. It set's within a minute or so, often less if the water pressure is minimal.
jomama45 is online now   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
Bathroom Remodel - Resurfacing Plaster over Concrete Block itcanadian Remodeling 2 05-30-2011 11:10 AM
Vinyl Window in Concrete Block Wrongwrench Carpentry 4 12-07-2010 11:21 AM
concrete block detached building, minimum space between openings rich624 Building & Construction 2 11-22-2010 08:48 PM
Can foam sealer be used to seal the spaces in concrete block? marksto Building & Construction 6 04-21-2008 08:48 AM
