-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   any way to patch a concrete block when wet (http://www.diychatroom.com/f105/any-way-patch-concrete-block-when-wet-135824/)
joelowrider 03-03-2012 03:43 PM
Is there anyway to patch a block that stays wet
joecaption 03-03-2012 04:29 PM
Not even close to enough info.
Try again.
concretemasonry 03-03-2012 05:01 PM
Are you trying to patch a crack/joint or just coat the surface of the wall.
Dick
user1007 03-03-2012 05:01 PM
Why is it staying wet. Not a good sign. :no:
joelowrider 03-03-2012 05:45 PM
It is a block wall for a pond I have a hole about 2 inchs wide for an over flow but it is allways pouring out I am going to do another drain on the other side about 3 in,chs higher so I need to plug this hole
user1007 03-03-2012 06:19 PM
So you answered your own question?
joelowrider 03-03-2012 06:50 PM
No its not awnsered I have no clue what to plug it with
Hardway 03-03-2012 07:10 PM
Dike
Dike hydraulic cement, I used to sell it when I worked in the hardware store. Can’t find a listing for Dike. The link below is for Quickrete, I don’t have any experience with Quickrete band. The Dike would work on flowing water.
http://www.quikrete.com/productlines/HydraulicWaterStopCementPro.asp
Writer’s information is for discussion purpose only and should be confirmed by an independent source.
user1007 03-03-2012 07:55 PM
You can waste money plugging it. But you need to determine what it is and why the wet and soggy block.
I use products from Abatron all the time.
Water. Gravity. Physics. Against the best products on the planet. Water will win brother. You have to source what it causing your block to fill with water. Or if you seal and fix it, the one next to it will fill next.
If you do not address the why your block is filling with water, and you seal it off so so it cannot harbor water? The water is just going to find itself to blocks nearby and cause you nightmares beyond those you already have.
Water is heavy and seeks low points. Cannot help it. Clogged gutters, bad grading and drainage could be causing that block to fill.
Hardway 03-03-2012 08:04 PM
Did you read the OPs post?:whistling2:
"It is a block wall for a pond I have a hole about 2 inchs wide for an over flow but it is allways pouring out I am going to do another drain on the other side about 3 in,chs higher so I need to plug this hole"
jomama45 03-03-2012 10:02 PM
You need a fast setting hydraulic cement, a professional grade like this would work best:
http://www.euclidchemical.com/elit/masonbrch.pdf
(Go to the bottom of the last page and look for the "Dam-It)
You typically want to mix it relatively quickly and create a ball of it on your hand (you really need to wear gloves with this stuff as it's very caustic) and force it into the hole. It set's within a minute or so, often less if the water pressure is minimal.
