Angles And Dimensions - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 03-29-2013, 10:16 AM   #1
Angles and dimensions
I'm building an out door fireplace, big enough to roast a hog on. I have pads that are 8' x 6'. How would I calculate my inside back angles and dimensions.
hickster is offline   Reply With Quote
Old 03-29-2013, 10:52 AM   #2
GBrackins's Avatar
Rewards Points: 2,108
got a photo or sketch of what you are trying to build?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 03-29-2013, 02:26 PM   #3
Rewards Points: 1,232
You will need to line it with firebrick, as well.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 03-29-2013, 05:40 PM   #4
I would start my calculations at the center of the pad and always compensate for the firebrick you're going to have to build into it all.
Just my 2 cents.
Metro is offline   Reply With Quote
Old 03-29-2013, 11:44 PM   #5
Rewards Points: 4,538
for an outdoor fireplace big enough to roast a hog on, you'd 1st want to know the size of the hog, no ?
howzabout layout your firebrick liner's 1st course on the conc then drawing pencil lines,,, once you've got your lines down, shouldn't be too difficult to make a cardboard pattern then who cares about angels ?
i think this is a fairly ambitious project for a newbie who doesn't even know the size of his guest hog
Old 03-30-2013, 09:18 AM   #6
cheif outhouse engineer
By definition a roaster hog is 100-120 pounds.
I would lay out the oven as suggested and then you can see what your cuts will look like. In this case it is probably easier to see the cuts, vs calculating them in advance.
Maybe your smarter than the average Joe, if so post your solution...
dakzaag is offline   Reply With Quote
Grambrel Roof Question - dimensions North178 Carpentry 3 08-08-2011 08:19 PM
fireplace dimensions on older home...can it burn wood? JPinSD General DIY Discussions 6 12-18-2010 09:40 AM
