Advice On Pavers Needed - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 10-25-2012, 08:33 PM   #1
Rewards Points: 137
Advice on pavers needed
I'm going to build wood stairs up to a small deck that continues up to the front door. The landing has a 4x6 concrete slab that will support the stair stringers. I want to cover the concrete landing with pavers before building the stairs. My understanding is that pavers are usually installed on compacted 3/4- and sand. Would laying the pavers on a mortar bed be OK? If so, would you use mortar between the pavers or some type of water resistant caulk? Thanks
Jack E is offline   Reply With Quote
Repainting Room With Peeling Paint: Advice Needed Magnetic Painting 8 10-15-2012 05:19 PM
Floating floor water damage - advice needed rumiat Flooring 3 05-28-2012 02:38 PM
Advice Needed on [UK] Home Repair Bill cookerz Building & Construction 1 01-09-2010 08:53 PM
Double Door Alignment Advice Needed Lovegasoline Building & Construction 6 12-15-2009 01:32 PM
bathroom floor tile job advice needed dbrew Flooring 14 01-23-2007 07:03 PM
