Advice Needed To Build A Brick Address Marker - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-23-2012, 04:55 PM   #1
Advice needed to build a brick address marker
I would appreciate any advice from you experts out there.
I want to build a brick wall about 6 feet long, 40 inches high and 14 inches wide. I will put a 16 inch wide by 3 inch thick by 72 inch stone on top of it.
In the center, I will install my house numbers and address.
Sort of like the one in this link:
http://www.google.ca/imgres?q=addres...t:429,r:18,s:0
As I am in a cold climate, NORMALLY, I would dig below the frost line and build a permanent foundation to support the structure and prevent frost heaving.
However, in this instance the marker would have to be placed slightly on the city portion of my front yard, so that it could be properly seen from the street.
Therefore is is possible that one day, I may have to move it or even remove it
Consequently I was considering building the structure on a concrete slab instead of the below grade foundation.
I would excavate about 8 inches below grade, lay 6 inches of 3/4 crushed gravel, tamp it and then pour an 8 thick inch slab of concrete (with wire rebar)as my base. The Slab would be about 7 feet long and 24 inches wide..........giving a surface area of 14 sq ft. The total weight of the structure would be about 2500 lbs (approx 200lbs per sq/ft)
I am not sure if this will heave. I am thinking this is similiar to a concrete pathway or the foundation of an ashphalt drive: neither of which usually heave, even in our climate.
My thought is that this foundation will simply "float" on the ground surface and water will not be able to accumulate due to the gravel base.
Constructing it in this manner will also allow me to level the structure if it does settle over time (as it can be partially raised by levering up one side).
I would appreciate your thoughts as this will be an expensive and labor intensive undertaking.
skitter is offline   Reply With Quote
Old 02-23-2012, 08:00 PM   #2
Concrete & Masonry
Rewards Points: 576
The only way to guarantee that it won't be affected by frost heave is to obviously go below the frostline with the foundation. You're taking a chance honestly, but it sounds like you're aware of the potential risks & willing to work at it to repair it if necessary.
To put things in perspective, and "cloud-up" my response even more, I can tell you that I would never attempt this as a contractor for a customer. That being said, I have a relatively heavy full masonry fireplace sitting directly on the corner of my patio, and I've yet to have any issues with frost in 3.5 years........
jomama45 is offline   Reply With Quote
Old 02-23-2012, 08:23 PM   #3
Thanks for the reply.
Im wondering.............how is it that concrete sidewalks generally do not heave from frost................as they dont go below the frost line?
Old 02-23-2012, 08:24 PM   #4
Rewards Points: 13,732
May want to run this idea past zoning and or the building dept. Build it to close to the road and you may well be told to take it back down.
Old 02-23-2012, 08:26 PM   #5
Concrete & Masonry
Rewards Points: 576
Alot of times they do & you'll never notice. If the ground surrounding the sidewalk moves simultaniously, how easy is it to tell?
Old 02-23-2012, 09:12 PM   #6
its well back from the road. I suspect the city wouldnt say anything. Other neighbours have large landscaping rocks or address markers that are obviuosly on city property.
The marker would look professional and have a small garden around it.........but you never know if a neighbour might complain.............so I dont want a foundation on it, in case it has to be removed.
Old 02-23-2012, 09:16 PM   #7
which makes me think that IN THEORY, allowing the cement pad to "float" on top of the soil would allow for ground movement without disrubting the marker.
I guess Im trying to figure out how an asphalt driveway doesnt seem to heave, even though its obviously sitting above the frost line (I have a large circular asphalt drive that is adjacent to the location I want to put the marker, and the drive seems to be stable)
If the driveway can sit on a bed of gravel and not move, cant the address marker do the same??
Old 02-23-2012, 09:25 PM   #8
I have a relatively heavy full masonry fireplace sitting directly on the corner of my patio, and I've yet to have any issues with frost in 3.5 years........[/quote]
-thats what I am thinking.............the ground under the address marker can freeeze and thaw, but it cant push the marker up out of the ground and cause the same kind of heaving as a fence post because the foundation isnt IN the ground as a post is.
Also the 3/4 crushed gravel will prevent water from accumulating under the marker. This means ice cant form to move the marker.
I envision it being similiar to laying patio stones or interlocking brick on a tampered level bed of crushed lime/gravel. If the base is properly laid the interlocing brick stays put for years.
But those are only MY thoughts, no doubt some of you have real experience on this topic.
Old 02-24-2012, 04:53 AM   #9
Rewards Points: 582
I have seen houses built on a concrete raft, which is similar to what you are thinking of. These were used where the subsoil was shrinkable clay and there were trees close by which could affect the ground. If you remove the trees the ground would heave, but the raft could coe with this.
stuart45 is offline   Reply With Quote
Lots of advice needed - exterior painting. lazzlazz Painting 1 06-20-2011 07:56 PM
Roofing plywood advice needed jimd206 Roofing/Siding 2 04-24-2011 11:58 PM
Advice needed on attic ventilation acdriverd15 Roofing/Siding 16 03-17-2011 06:03 PM
Need advice on quantity of primer and paint needed laurat Painting 8 01-01-2011 10:53 AM
Vaillant advice needed jdg88 HVAC 6 12-14-2010 05:11 PM
