Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 04-12-2012, 02:22 PM   #1
heinlein0311's Avatar
Adhering manufactured stone to Concrete
I'm finally in the stage of installing my manufactured stone veneer to the poured concrete foundation wall. The walls are clean. A local mason told me I needed to apply a scratch coat to the wall before applying stone. So I did in one section, but to me it seems like the scratch coat is very brittle. I mixed up some mortar and applied a stone to it and it stuck fairly well, I also applied one to just the concrete wall which stuck good as well. Do I really need to apply a scratch coat? I'm afraid the scratch coat will not adhere well and start coming off, taking the stone with it.
heinlein0311 is offline   Reply With Quote
Old 04-12-2012, 09:34 PM   #2
Concrete & Masonry
If the walls are clean of any dirt, form release, contaminent, etc... there is no need for a scratch coat. As you suspect, it would only serve as a failure point and merely be redundant, with no benefit. I would highly recommend using a little bonding agent in the setting mud though.
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
PaliBob (04-13-2012)
Bamboo on modified concrete pad jhanson Flooring 0 10-08-2011 12:58 PM
High Rise Building methods - US versus Oz - Steel versus Concrete Jado Off Topic 17 09-15-2011 09:47 PM
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 02:20 PM
Prep Concrete Block Wall for Natural Stone Veneer SCPete Building & Construction 2 03-06-2011 12:19 PM
Tips For Pouring Concrete? Root issues? Thoughts? kronic24601 Building & Construction 5 02-14-2011 07:52 AM
