Adding A Wood Burning Fireplace - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 08-08-2012, 09:06 PM   #1
Rewards Points: 16
Adding a Wood Burning Fireplace
I currently am in the process of adding a fireplace insert for burning wood. I have brick around the wall. I also have slate tile underneath. What would be the next step for making the walls around the fireplace. What type of material would I use for that. I have the picture so it makes more sense.
Thanks for your help
guitar548 is offline   Reply With Quote
Old 08-08-2012, 09:12 PM   #2
Rewards Points: 12,876
Steel studs and 5/8 fire code drywall.
Old 08-08-2012, 09:17 PM   #3
Rewards Points: 16
Would you put one steel stud on each side of the fireplace?
Old 08-08-2012, 09:53 PM   #4
Civil Engineer
Rewards Points: 4,522
I think your terminology is a bit off. A fireplace insert generally refers to a wood burning stove designed to be installed inside an existing fireplace. I have just such a unit, made by Jotul. What you have appears to be a freestanding wood stove, since I don't see a fireplace anywhere in the picture. Regardless, regulations for legal, safe installation of a wood burning unit are typically available at your local building inspector's office. Your inspector should be able to tell you what clearance you need, what types of material may be used, what type of flue you need, and required dimensions for the hearth.
Old 08-08-2012, 10:03 PM   #5
Concrete & Masonry
Rewards Points: 470
That is, with out a doubt a "zero-clearance" fireplace unit, certainly not a wood stove.
Ideally, you would use the model/serial number to find an installation manual online, or from a dealer. In that manual, it will give you every piece of information you need on framing in around the unit, including clearances, and type of flue pipe. For starters, you can't frame any lower than the "stand-off's" on top of the unit (the upside down "V's)............
jomama45 is offline   Reply With Quote
Old 08-08-2012, 10:03 PM   #6
Dan that is a style of insert that's made to have walls built around it, it's not really made to be a free standing unit. Look at the top of it.
If you know the company that made it there will be complete directions on there web site on how to build the walls.
I'm not a steel stud framer so i was hoping one of the commercial framers would see your post.
Old 08-08-2012, 10:04 PM   #7
DIY staff
Rewards Points: 7,174
Daniel--that looks like a zero clearance fire place box to me---
Look in the trash for framing instructions----The manufacture should have included them with the unit--
Wood framing is typically used---however, like Joe mentioned, steel studs might be required by code in your area.
Local code always wins--so read up!
Old 08-08-2012, 10:55 PM   #8
Rewards Points: 16
Here is the manual for it
http://fmisupport.hcents.com/supportdocs/54024F.pdf
So I can use wood studs and fire resistant drywall?
Old 08-09-2012, 08:02 AM   #9
DIY staff
Sorry, my computer doesn't like PDF files this morning---you read it--what is the clearance to combustibles?
Old 08-10-2012, 11:17 PM   #10
MINIMUM CLEARANCES TO COMBUSTIBLES:
• Back and sides of fireplace …………………..1/2” Min.
Note: the ½” clearance is not required at the nailing flanges
• Floor* ………………………….…………………0” Min.
*See step 2 of “Installing the Fireplace” – next page
• Wall to front of Fireplace ……………………….36” Min.
• Perpendicular Wall to Opening of Unit ………...14” Min.
• Top Spacers …………………..…………………..0” Min.
• Mantel Clearances …………………………… see page 7
“Finishing your Fireplace”
• Chimney Outer Pipe Surfaces ……………………1” Min.
WARNING: DO NOT PACK REQUIRED AIR SPACES WITH
INSULATION OR OTHER MATERIALS.
MINIMUM/MAXIMUM CHIMNEY HEIGHT:
The MINIMUM height of the chimney, measured from the
base of the fireplace to the flue gas outlet of the termination, is
11 feet for straight flue or a flue with one elbow set. The
maximum distance between elbows is 2 feet. The maximum
height of any system is 20 feet. This measurement includes the
fireplace, chimney sections and the height of the termination
assembly at the level of the flue gas outlet (see pg. 6, fig. 14).
21boat is offline   Reply With Quote
Old 08-11-2012, 07:22 AM   #11
DIY staff
21boat--thank you---1/2" sides and back--0 at the flange--1 for the flue---that helps
Old 08-21-2012, 09:56 PM   #12
Rewards Points: 16
have problem with a supporting stud in ceiling
Thanks for all the replies. The attachment picture shows the metal studs installed. Don't know if I did that right. Any ways the piping is 11 inches in diameter and I have a support stud in the ceiling. There is no attic in this attach part of this house. Can I cut that out or move to have the pipe go through?
Adding a Wood Burning Fireplace-img_20120821_214718.jpg   Adding a Wood Burning Fireplace-img_20120821_215000.jpg
Tags
fireplace , wood burning firplace
wood burning fireplace llckll General DIY Discussions 16 12-23-2011 01:32 PM
wood fireplace trash stuck in vents Limeybstrd Appliances 0 10-24-2011 02:22 PM
Encasing a brick fireplace in wood Laborfree Carpentry 3 10-23-2011 08:40 PM
adding wood stove to boiler flu? wombosi HVAC 7 12-14-2009 06:27 AM
Adding a gas fireplace BionicWoman Remodeling 7 11-08-2007 01:53 PM
