Adding A Fireplace - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 07-14-2012, 08:15 PM   #1
Adding a fireplace
Hi guys & gals,
I am in the process of building a patio and I wanted to add a fireplace.
The fireplace would not be next to the house, but on the other end of the patio. I do not have a concrete footing to allow for a traditional fireplace, but really want one. Is there anything I can do to have a stone looking fireplace?
Thanks,
Pujo
Pujo is offline   Reply With Quote
Old 07-14-2012, 08:44 PM   #2
DIY staff
Rewards Points: 7,174
Without a proper set of footings I think you are out of luck--I'm not a mason so we will see what a mason thinks--but even the artificial stone is heavy--and a water resistant frame work is too---
Old 07-16-2012, 06:09 PM   #3
tav
your patio
we also put in a cement stamped patio which by the way came out awsome,
we had the contractor made a curve with the form so we could put a fire pit.
just have to shut the windows on the house or you'll smoke it out.....lol
tav is offline   Reply With Quote
Old 07-16-2012, 06:11 PM   #4
tav
your patio
just have to shut the windows on the house or you'll smoke it out.....lol.
Old 07-16-2012, 06:12 PM   #5
tav
sorry for the double
Old 07-16-2012, 08:43 PM   #6
Rewards Points: 152
If your looking for an "outdoor fireplace" made out of any type of masonry then you will need at least 8" of concrete to support your structure. You can always go with a "fire pit" which you could build out of splitface landscape block which you can burn in. A simple DIY project. You could also run a gas line to it and burn that way.
TRUEPRO is offline   Reply With Quote
Old 07-16-2012, 09:30 PM   #7
What is a proper footing for a fireplace?
Old 07-18-2012, 05:21 PM   #8
Rewards Points: 152
replyto
12345
Originally Posted by truepro View Post
if your looking for an "outdoor fireplace" made out of any type of masonry then you will need at least an 8" footer of concrete placed 3"-4" below grade and 4" wider on all sides of outer perimeter of actual structure dimentions. .
Fireplace Masonry - Adding stone inside the firebox DNB Concrete, Stone & Masonry 3 02-06-2012 12:24 PM
How to go about replacing fireplace surround? NewHomeDIYGuy Remodeling 9 01-26-2012 09:56 PM
Adding a fireplace upstairs crlove General DIY Discussions 1 03-24-2009 12:54 PM
Possible to build direct-vent fireplace? DIYerself General DIY Discussions 3 12-22-2007 10:07 PM
Adding a gas fireplace BionicWoman Remodeling 7 11-08-2007 12:53 PM
