Adding Brick To Fireplace Front - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 12-27-2013, 12:39 PM   #1
Adding brick to fireplace front
I am working on refacing my fireplace (shown in picture). I removed the tile, and now the front is concrete block. You can see that it has a recessed area at the front with no support underneath of 1.5" deep, 6" high and ~4' wide. I would like to know if I could fill the area with concrete bricks (1.25" deep, 3.5" wide, 6" tall) to make the top/front flush around the fireplace insert. If I built a 2x4 support underneath them to hold them in place while curing, is there a product that could be used to permanently mortar/cement/hold them in place (even after removing the support)?
After adding the brick, I'm going to reface the entire front with new tile, so that's the reason for trying to fill in the recess (I want a flush look).
Thanks!
krummelk is offline   Reply With Quote
Old 12-27-2013, 03:51 PM   #2
Rewards Points: 3,512
If I understand your question,you need a lintel to permanently hold the filler you would use to make the surface flush.
Canarywood1 is online now   Reply With Quote
Old 12-28-2013, 02:48 AM   #3
Rewards Points: 4,578
looks like your wife left a hammer & chisel it shouldn't be a problem for her to knock out tile & lay brick on a floor level mortar bed while you watch the game happy to help
woody & i see this differently so i probably don't understand the goal,,, IF its to have a flush front upon which to re-tile, why not do as above,,, 2 brick courses won't add much weight
Old 12-28-2013, 07:49 AM   #4
MarginallyQualified
Rewards Points: 2,464
Originally Posted by krummelk View Post
I removed the tile...
Nothing better to do?
Old 12-28-2013, 02:58 PM   #5
so how does removing tile change anything ?
Old 12-31-2013, 03:17 PM   #6
Concrete & Masonry
Rewards Points: 548
I would probably thinset 2 layers of concrete backer board over the fireplace opening. If you use a good thinset, it should stick w/o any props. You could also pre-drill a few Tapcons into it as well to help hold it in place w/o sliding down......
jomama45 is offline   Reply With Quote
The Following User Says Thank You to jomama45 For This Useful Post:
Old 01-01-2014, 05:09 AM   #7
& here I wuz looking @ the btm ( hearth )
Closing fireplace - Air brick Question adamavis Concrete, Stone & Masonry 4 07-28-2013 07:37 PM
Brick Fireplace Makeover? dezandseth Concrete, Stone & Masonry 11 06-12-2013 12:59 AM
brick fireplace conversion frankpoto General DIY Discussions 2 01-30-2012 08:31 AM
Can you seal brick on fireplace? mrs1885 Remodeling 3 03-29-2011 10:52 AM
Care of Brick front sherlock General DIY Discussions 2 08-12-2005 06:41 PM
