Acid Staining Concrete - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 06-20-2013, 09:24 PM   #1
Rewards Points: 422
Acid staining concrete
When acid staining a concrete slab floor, is it best to do it when the concrete is new? Does new concrete have to cure or age before doing it?
We are thinking of using a frost wall and concrete slab floor when we build a 3 season porch, hence the above questions. We are thinking of doing the frost wall and slab sometime before winter, and doing the walls and roof next year. If we did that, is it best to stain the concrete right away, or wait until the porch is built? Thanks.
Jim McC is offline   Reply With Quote
Old 06-21-2013, 06:21 AM   #2
Rewards Points: 4,656
cured concrete reacts to acid-stain better than new,,, this is because the ' free lime ' is more readily avail AFTER the conc's cured,,, metallic salts in acid stain change the free lime's color,,, its much easier predicting color results when staining as the conc's dry,,, hope this makes sense to you,,, if its difficult to understand, just wait & stain prior to installing the baseboards
make sure you also protect the conc from dirt & abuse,,, not even a board lying on it
Old 06-21-2013, 09:08 AM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 404
Stay away from sealers before you do the staining.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
Old 06-21-2013, 09:15 AM   #4
thanks, jim - excellent point no curing blankets, plastic sheeting, curing compounds, water spray - no nuttin' - just a regular curing process
Old 06-21-2013, 11:55 AM   #5
Rewards Points: 422
Thanks guys. But how do I rinse the floor after staining if the walls are up? Do I do it before the interior and exterior wall surfaces are up?
Old 06-21-2013, 01:25 PM   #6
that's why they make wet/dry vacs along w/scrujb brushes on a stick don't forget to run plastic sheeting 2'0 up the walls or however far up your spray pattern/technique requires don't ask me how i know this - i just know
Old 06-21-2013, 02:35 PM   #7
Rewards Points: 422
Wouldn't it make more sense to stain the floor after the stud walls and roof are up, but before the interior and exterior wall finishes are installed? Thanks.
Old 06-21-2013, 07:24 PM   #8
in a perfect world, it would if you can figger out how to keep the framers from leaving dirt/marks/trash & anyone else from marking up the floor, let us know
we haven't even discussed proper floor prep PRIOR to staining or what tools work best for prep yet
Where to buy concrete acid stain in Montreal ConcreteStain Concrete, Stone & Masonry 3 05-18-2014 09:27 AM
Cleaning concrete for staining Shanna Flooring 6 03-19-2011 01:34 PM
Concrete: Top Cast vs. Acid Stain/Wash sportinwla Landscaping & Lawn Care 0 07-09-2010 02:15 PM
Muratic acid on aluminum clad windows jarrodbowles General DIY Discussions 25 05-01-2009 04:42 PM
Concrete Acid Coloring Taipans Landscaping & Lawn Care 1 10-09-2008 06:45 AM
