Acid Stain On My Granite - Concrete, Stone & Masonry - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-27-2012, 07:58 AM   #1
acid stain on my granite
the heater repair person sat down coil cleaner on my black granite counter top and it left a couple white stains. Is there something to do to bring back the color? HELP
ajward is offline   Reply With Quote
Old 03-02-2012, 01:42 PM   #2
That all depends on...
The method to remove a stain from a granite countertop will vary depending on the specifics of the stain. Without knowing more about the stain I'm leery about suggesting any possible fixes. With granite you have to be careful what you try because you may make the matter worse....
Hopefully this reply will point you in the right direction even if it doesn't actually solve the problem for you. Here are two resources that may help you in restoring your kitchen countertop:
1.) Contact the place you got the granite from. They may be able to offer you suggestions on cleaning the countertop and removing the stain. For a fee, they may be able/willing to come out and take care of it for you.
2.) Check out this PDF from the Marble Institute of America (a.k.a. MIA). It's a great resource that a lot of stone fabricators and facilities refer to. It can tell you more about removing the stain based on what kind of stain it is exactly. It's also just a good reference to have on hand for general stone maintenance.
I hope this helps!
Cincinnati Kitchen Countertops
akwebb is offline   Reply With Quote
Old 07-16-2012, 09:50 PM   #3
mikemakeitso's Avatar
This link may help...
mikemakeitso is offline   Reply With Quote
Finding a good granite fabricator for kitchen countertop tseverson Kitchen & Bath Remodeling 5 04-20-2012 02:50 AM
Granite stain Robert A Plumbing 2 01-25-2010 02:47 AM
Stonemark & Silestone Countertops......??? DepotDweller Remodeling 9 06-25-2009 11:44 AM
"Stained" granite with acid cleaner - help!!! aggiejess7 Kitchen & Bath Remodeling 5 05-26-2009 02:00 PM
granite countertop stain? Is there anything that can be done? MrLinux Remodeling 4 02-13-2008 08:52 AM
