Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 02-15-2012, 08:44 PM   #1
6" Hole in Concrete Block / Brick
Not going to be perfect but will a Hilti TEC6 using drill bit to score the circle and then a grinder to finish the circle be a okay tool method to make a 6" hole in cement block/brick ?
Just adding a bathroom vent fan
mobiledynamics is offline   Reply With Quote
Old 02-15-2012, 08:54 PM   #2
Why 6"? Bathroom fans are 3 or 4" not 6".
A diamond core drill would be the best way, second would be a series of 1/2 holes with a hammer drill and clean it up with chisle not a grinder.
Make sure you drill from the outside in.
If not you will blow out the brick.
Old 02-16-2012, 10:40 AM   #3
joecaption.
Silly question, "drill from the outside in.
If not you will blow out the brick", please explain this so i understand the logic.
Thanks in advance.
quincy is offline   Reply With Quote
Old 02-16-2012, 10:47 AM   #4
If you drilled from the inside as the drill starts to break through the brick it blows out the face of the brick. Drill from the outside and you will see nice round holes in the face of the brick but the block will most likly get blown out, better to have the block mess up then the brick.
quincy (02-16-2012)
Old 02-20-2012, 08:31 AM   #5
If you are going through block, as in hollow core cinder block, examine a spare block first. Looking down from above you will see two cavities. If you can, try to center your hole in one half of the block or the other to drill through those cavities....
Chemist1961 is offline   Reply With Quote
Covering a large hole in concrete block swolfxx0 Building & Construction 5 01-25-2012 04:42 PM
Brick Ledge when using cinder block DaveMo Building & Construction 5 07-13-2011 10:46 AM
Bathroom Remodel - Resurfacing Plaster over Concrete Block itcanadian Remodeling 2 05-30-2011 11:10 AM
Concrete Patio with brick ribbons vactek Building & Construction 4 04-11-2010 11:10 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 08:17 AM
