Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-14-2012, 06:54 AM   #1
3" holes in foundation
I have 4 of these 3" holes in my foundation walls. I do not know what they are for. One below the deck has a 3" corrugated plastic pipe that runs down it. I would like to seal them all up, but do not know what purpose they serve. Any help would be appreciated. Thanks
Babybundy is offline   Reply With Quote
Old 11-14-2012, 08:44 AM   #2
Interesting... Perhaps it was somebody's attempt to fix a drainage issue- do you have any water issues in your basement currently?
You mentioned that one hole has corrugated piping inside of it... Can you tell if the piping extends out past the foundation or not?
myfirstrodeo is offline   Reply With Quote
Old 11-14-2012, 12:31 PM   #3
The piping does not extend past the house. These holes arejust slightly above grade and are basically evenly spaced through the entire wall of the home. The holes are also below the concrete floor in the basement from what I can tell.
Old 11-14-2012, 01:27 PM   #4
JOATMON
ddawg16's Avatar
For just one hole.....and above grade....I would speculate a dryer vent.....but 4 holes?
Some people do strange things....
Do you know the history of the house?
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
Old 11-14-2012, 01:38 PM   #5
I was thinking an old sump pump outlet or something... But agreed... With that many holes, I'm not quite sure...
What area/terrain is the house in?
Old 11-14-2012, 08:47 PM   #6
who cares what they were for. if you don't want em, patch em up.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Foundation wall project and spread footings WillK Building & Construction 0 08-31-2011 01:46 PM
Is tape necessary to repair holes in drywall (in garage)? Scotch99 Drywall & Plaster 4 08-22-2011 02:08 PM
1/2" holes drilled every 3" inches around foundation???? amerren Building & Construction 5 04-13-2010 11:45 AM
Block Foundation w/Hundred Seep Holes? Jodust11 Building & Construction 9 04-13-2010 11:41 AM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 09:39 AM
