-   Concrete, Stone & Masonry (http://www.diychatroom.com/f105/)
-   -   2" Hole in Fake Stone? (http://www.diychatroom.com/f105/2-hole-fake-stone-157071/)
DWooderson 09-17-2012 10:58 AM
I'd like to relocate some AV equipment to the closet behind this stone facade. I'm told that this is artificial stone.
There is a small existing hole in another location of this stone wall already (visible in the second photo, to the left of the plywood), and I noticed that there is a metal mesh behind the stone. This hole just runs down the wall.
I need a new, larger hole about 12" from the floor, and it needs to go thru the wall (not down the inside of the wall). The other side of the wall is drywall.
Should I use a chisel and go at the mortar first, then expand into the stone as needed? The existing hole was made using this technique, but it's smaller. Or should I use a drill, and if so, what sort of drill and what sort of bit?
Thanks!
https://lh4.googleusercontent.com/-H...640/stone1.jpg
https://lh3.googleusercontent.com/-I...800/stone2.jpg
joecaption 09-17-2012 11:58 AM
Diamond core drill is what I would use.
Works like a hole saw.
jomama45 09-17-2012 06:28 PM
You don't need a couple hundred dollar diamond bit and core rig to get through cultured stone. Try to find a "Rem-grit" holesaw bit, and first attempt drilling it in straight drill mode. If you don't get anywhere, you may need a small hammer drill to aid in the drilling. I'd be aprehensive to go at it with a hammer and chisel, especially on a wood framed interior wall.
DWooderson 10-01-2012 01:58 PM
I picked up the remgrit, and I was amazed at how easy it was. I don't think this manufactured stone is very dense.
I drilled a 2" dia hole, and I drilled out two cores, about 2" deep ea., it probably took 60 seconds total of actual drilling time.
I've completed this project, the AV equipment has all been reloacted to the closet behind this area.
Thanks!
