Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Concrete, Stone & Masonry
Old 11-21-2012, 07:36 AM   #1
Is 100% silicone fine for sealing cracks in cement patios?
Hi, I have a few cracks in my cement patio and I can get 100% clear silicone for only $3 a cartridge. I know that they make caulks specially made for concrete and cement (I believe they are polyurethane) that are self-leveling and stuff.
But besides the fact that the special stuff is self-leveling and attempts to match the color of your concrete, what is the benefit to buying the special concrete caulk over regular 100% silicone?
Is 100% silicone fine to use to fill in the cracks in my patio?
amodoko is offline   Reply With Quote
Old 11-21-2012, 04:28 PM   #2
gravity always wins
Regular silicone gun grade caulk has some adhesion isues when it comes to masonry. Urethanes are your best bet. You can buy gun grade urethanes like Sikaflex and others.
The Following User Says Thank You to Maintenance 6 For This Useful Post:
amodoko (11-21-2012)
Old 11-21-2012, 06:38 PM   #3
Okay, that makes sense to me, the polyurethanes just adhere better than silicone to masonry. Thanks for the information, I appreciate it
Old 11-22-2012, 06:52 AM   #4
IF you were just talking cost of materials, silicone wins,,, we've used 1,000s of 55gal drums of 100% silicone sealing & resealing hgwy/airport jnts,,, the key is NOT material - it IS the prep for sealing the crack - proper preparation WILL allow sealants to perform properly - adhesion isn't an issue IF you CLEAN the crack sidewalls after diamond sawing the crack to the correct dimension so material selection isn't a big deal for your work.
any loss of adhesion can be traced to improper prep OR an incorrect material selection for the desired use ( cohesion faults usually )
can we/i presume 6 refers to what is avail at the apron / vest store ? imho, IF you can't prep the crack properly, stuff anything into it - even caulk.
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
The Following User Says Thank You to itsreallyconc For This Useful Post:
amodoko (11-26-2012)
Old 11-25-2012, 07:51 AM   #5
gravity always wins
Big 10-4 on the joint prep. There are "next generation" silicones out there that are excellent for use with masonry. You won't find them in a cardboard tube at the box store for $3.00 though. No caulk is going to survive if you ignore the joint prep and design. In fact there are very few caulks out there that are bad. Just sloppy people putting them into bad joints or wrong applications.
Recaulking at previously silicone-caulked shower door frame hffeagan Kitchen & Bath Remodeling 33 01-03-2013 12:58 AM
flat cement roof naturallight Roofing/Siding 7 05-11-2012 10:25 PM
basement wall waterproofing Jenbarkel Building & Construction 9 08-30-2010 06:37 PM
Fine cracks in grout. stevez General Discussion 10 01-25-2010 12:08 AM
Cement Utility Sink - Cracks and Leaks amazinlittledevil Plumbing 3 01-25-2007 03:59 PM
