Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 01-16-2012, 10:08 AM   #1
wrought iron security door frame
The back "dutch-style" door of our brick house is between two windows that look into our kitchen. There have been a lot of break-ins recently in our town, and I notice signs that someone has been trying to force our door open with a pry-bar near the latch where the diagram below has an (x). They're forcing the pry-bar between the door and the door jamb; because there's nothing solid behind the door jamb, there's some flex in the frame.
..brick....brick....brick..brick
window ||d o o r|| window
window ||d o o r(x) window
..brick.. ||d o o r|| ..brick..
..brick.. | cement | ..brick..
So I am looking for a wrought-iron security door.
The one company I phoned said their wrought iron security door frame is L-shaped, not a rectangle. Are all of the frames L-shaped? Are there any pre-hung wrought iron security doors that are designed to fit into a rectangular four-sided metal frame that could be fastened with lag bolts into the brick wall on left and right side of the lower half of the door, into the cement at the foot of the door, and into the brick above the door?
diy888 is offline   Reply With Quote
Tags
security door
Wrought Iron + Stone Fence bkboggy Building & Construction 8 06-07-2011 05:22 PM
Clean up and paint very rusted wrought iron railing pnschi Building & Construction 4 10-25-2010 11:07 PM
Wrought iron railing dimensions tns1 Building & Construction 5 07-17-2010 12:09 PM
Building a Wrought Iron Gate? CptSD General Discussion 4 04-03-2009 05:25 PM
Wrought Iron Railings for Stairs ThomF Carpentry 3 11-01-2006 08:04 PM
