Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 02-04-2013, 12:42 PM   #1
Wood window repair /caulk
I have some 1950's Anderson windows(at least it says Anderson on the metal frames for the screens) that we are getting redy to re-paint. I will scrape/sand most of the old paint, but I am not sure what to do about the cracked caulk or glazing between the sash and the glass. Should I dig all the junk out ant try to run a bead of caulk in there?
Wood window repair /caulk-image-4129387574.jpg   Wood window repair /caulk-image-4213539864.jpg
fullermatt is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Wood window liner, no casing rustyjim Drywall & Plaster 1 04-08-2012 07:04 PM
rotted wood window in bathroom sgsnow Painting 2 06-18-2010 02:27 PM
Crooked window sill in old wood house bofusmosby Carpentry 36 04-13-2009 09:34 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
