Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 08-21-2012, 05:23 PM   #1
Wood Rot repair under sidelight
Most of the posts I've read thus far deal with window sills and other areas but the panel under my sidelight glass is rotting through into the foyer. I have some other minor wood rot that I am using epoxy filler on but once I remove this section, I can't use epoxy to fill. I was thinking of cutting a square piece to fill it in and then use epoxy for the seam line or to place an oversized piece over it (once I remove the rot) and use trim to make it all nice. Any ideas?
sygood is offline   Reply With Quote
Old 08-21-2012, 06:11 PM   #2
Exterior Construction
Windows on Wash's Avatar
I think you are going to find that it will rot out pretty quickly.
You theoretically could pull the sidelite and put another one in but again I think the effort might wasted on fixing that door.
Old 08-21-2012, 07:29 PM   #3
Super Moderator
Windows on Wash is right--That's some rather advanced carpentry---I have done that repair several times---that side light must be removed-
to make it look truly professional you will need clamps, a surface planer,table saw and a router with an assortment of bits and a multi tool or back saw.
If you have the desire,I'll walk you through it---a filler panel will be needed while the work is done----I could do it in 6 to 8 hours---you might need three times as long---that is a common door and might be easier to just replace,as you will have rotting wood in the floor structure and fixing the side light won't address that.---Mike----
Windows on Wash (08-21-2012)
Old 08-31-2012, 01:23 PM   #4
Bombastic Idiot
notmrjohn's Avatar
That's the first issue to address. sy, you saisd you were dealing with other "minor" rot. It might not be as minor as you think, you are filling the rot you can see. Find the source of the water and correct that problem first. Then, if the rot doesn't go too high in that light, a panel and trim plan, while not "truly professional," could be structually and aesthetically acceptable. If this is one of a pair, you'll have to do same trim scheme on other one so they look like they're " s'posed to be that way."
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Wood siding repair... simeltzer Painting 11 08-03-2012 02:08 AM
How can I repair scratches in cherry wood? smokey847 Painting 3 07-02-2012 06:59 PM
Best way to repair rotted structural wood member? miamicuse Carpentry 20 11-19-2011 05:30 PM
ICF vs. Wood Framed JackOfAllTrades Building & Construction 31 11-01-2011 04:14 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 12:19 PM
