Wood Muntins/Grids/SDL - Attaching To Glass - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-21-2013, 08:46 PM   #1
Rewards Points: 45
Wood Muntins/Grids/SDL - Attaching to Glass
I have been asked to "revive/rebuild" some solid wood muntins/grids that act as simulated divided light for a glass double door (see pics below). The sets on the exterior are shot due to weathering and/or adhesive has come off. The sets on the interior are fine and will not budge. The original builder attached them directly to the glass pane with what appears to be a "silicone-self-stick-roll" that was just cut to length. It is uniform in thickness. Imagine a clear, double-sided tape. The wood pieces are basic 3/4" wide x 1/2" thick stock.
Any experts out there that use a similar product or any other attachment method that would be effective and still look good? I would like to avoid the use of any "clips".
Thanks in advance for any thoughts...
RunningSparky is offline   Reply With Quote
Old 10-09-2013, 12:30 PM   #2
Rewards Points: 45
This is way after the fact, but thought that someone else might be in the same boat down the road. This product is fantastic for outdoor application. Only been 3 months, but, Oklahoma weather can throw a lot of curve balls.
http://crlaurence.com/crlapps/showli...5&ModelID=1362
Old 10-09-2013, 06:53 PM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Sorry I missed your original post, but you found the answer: double sided tape.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
What is the best way to hang a heavy antique wood framed mirror to a glass wall jimmcfarlane Building & Construction 3 10-11-2012 07:06 AM
Attaching a support to a shower glass partition john_bry Kitchen & Bath Remodeling 0 09-26-2012 09:31 PM
Glass on greenhouse roof Flavio Building & Construction 16 07-15-2010 07:37 AM
Attaching A lot of wood to wall MakinItHome Building & Construction 4 08-22-2009 07:26 PM
flooring frankiedog Flooring 7 12-05-2008 01:05 PM
