Wood, Fiberglass, Or Steel Exterior Door? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-21-2011, 05:11 PM   #1
Wood, Fiberglass, or Steel Exterior Door?
My home entry way has a double door made from fiberglass, which has faded, and my wife wants to replace it with a different style. What are the questions one should ask when choosing a new exterior door material such as wood, fiberglass, or steel?
dv817 is offline   Reply With Quote
Old 07-21-2011, 05:16 PM   #2
Framing Contractor
Rewards Points: 118
1) Does the door qualify for the Energy Tax Credit (10%)?
2) What is the advantage of each door type?
3) What is the price difference of each door?
sixeightten is offline   Reply With Quote
Old 07-21-2011, 05:35 PM   #3
kwikfishron's Avatar
Rewards Points: 394
Fiberglass is always my first choice, they don’t rot, swell or rust.
A fiberglass door can be stained or painted to look just like a wood door.
kwikfishron is offline   Reply With Quote
The Following 2 Users Say Thank You to kwikfishron For This Useful Post:
HomeSealed (08-12-2011), tpolk (07-27-2011)
Old 07-21-2011, 06:33 PM   #4
I have fiberglass doors right now, and I the finish is fading much sooner than anticipated. Refinishing them is almost as expensive as purchasing one door.
Old 07-22-2011, 07:13 AM   #5
Rewards Points: 154
steel hands down, dont trust no one
wood breaks easily, so does fiberglass
awdblazer is offline   Reply With Quote
Old 07-27-2011, 10:49 AM   #6
Rewards Points: 5,336
I don't know how repainting or re staining a door is almost as much as a new door, with or without installation.
Ron
B. Franklin 1759
Old 07-27-2011, 11:43 AM   #7
AGWhitehouse's Avatar
I agree Ron, must be using automotive paint?
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 08-11-2011, 08:57 AM   #8
My front door is steel and it is original to when the house was built in 1987. I have painted it a few times over the years, but structurally and functionally, it is the same as when I bought the house in 1990. It has endured 24 years of the heat and humidity of south Florida as well as three hurricanes.
David
Jessidog is offline   Reply With Quote
Old 08-12-2011, 08:31 AM   #9
Home Performance
HomeSealed's Avatar
Rewards Points: 712
How fast the finish fades has far more to do with the quality of it and the method that it is applied, than the material of the door itself. Fiberglass doors imo are the best option. The security and energy efficiency will depend on the "grade" that you get. I can tell you that a nice fg door like Thermatru or Provia will be more secure, energy efficient, and last way longer than a cheap steel door from a box store. I've seen those start rusting after 5 years up here in WI... A high quality steel door such as one from the manufacturers mentioned is not a bad choice, although I still prefer fg. If you go steel, stay away from 24 gauge. Go at least 22 if not 20, and also make sure to get a steel edge. The wood edge doors are junk.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Tags
door , door design , door frame
Fiberglass door with wood sidelight JimV Windows and Doors 4 04-25-2011 11:31 PM
converting wood to steel for window header Dan S Building & Construction 7 05-22-2010 01:44 PM
Wood furniture care/ Cleaning (I ?!#?!? up) bli182nk General DIY Discussions 0 05-22-2010 01:31 AM
Is stripping/sanding to bare wood necessary? hf12358 Painting 13 09-06-2009 09:14 AM
Exterior door type - wood, steel, etc hellothere123 Building & Construction 15 08-13-2009 08:39 PM
