Windows Too Thick For My Old House - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-31-2015, 06:46 PM   #1
Rewards Points: 108
Windows too thick for my old house
I can't believe it, but I ordered windows that are too thick for my house. The thickness of the old windows are 2 3/4" and the new ones are 3 1/4". As a result, I have about 1 3/8" sticking out from the house instead of 7/8", and this is definitely wider than the trim that I bought. Any suggestions?
-Jeff
jeffdoesrepairs is offline   Reply With Quote
Old 05-31-2015, 06:55 PM   #2
Rewards Points: 3,753
Unless it is something unusual, you will need to retrim the inside. The standard stud wall is 3.5 + drywall + outside siding.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 05-31-2015, 07:15 PM   #3
Rewards Points: 2,210
Vinyl Jambs are usually hollow and do not trim well.
Can we have a picture of the inside as well?
You can use some 1/2" material and then your brickmould on that on the outside.
Or slide your wdw in and a 1/2" material on the inside then your casing. Looks ok especially with thinner casing.
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
MT Stringer (05-31-2015)
Old 05-31-2015, 07:17 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I think colby was referring to "the trim" and not trimming the window casings.
Since he included measurements, I believe his suggestion is to move the windows inward and re-trim the openings.
The Following User Says Thank You to nap For This Useful Post:
mae-ling (05-31-2015)
Old 05-31-2015, 07:33 PM   #5
kwikfishron's Avatar
Rewards Points: 224
I don't see what the problem is other than the new is slightly (1/2") thicker than the old (not an issue imo). 3 1/4" is pretty typical for a vinyl window. If the inside looks good then trim out the outside with whatever you want. Personally, I like the exterior trim to be proud of the window.
kwikfishron is offline   Reply With Quote
Old 05-31-2015, 07:48 PM   #6
Rewards Points: 108
So I'm thinking I could just use some pressure treated 2x4s for the trim and it will be pretty dang close. It won't match the trim above it between the upper and lower siding pieces. Thoughts?
I can definitely cut back the drywall going up to the window to move it farther in if I wanted, its just more work with a multi-tool, and a bit of a mess. The ledge would be smaller when I put it in too.
Old 05-31-2015, 07:54 PM   #7
Rewards Points: 224
Simple stuff, do what you need to do to make it look right for you. Sorry if the plug and play didn't work out. Welcome to the real world.
The Following User Says Thank You to kwikfishron For This Useful Post:
Old 05-31-2015, 07:57 PM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 1,194
If it was me, I'd be removing the drywall on the inside. Drywall is not exactly a good thing to trim the inside of a window with. Even if your windows don't leak, you will get your greatest moisture next to the window.
If anything I would be wanting to pull it all off to inspect for any water damage.
And...I think it would be easier to flash the outside with the window flush. Unless it doesn't rain where you live, I think you are looking at some potential water leaks trying to flash that window the way it is.
I would install some flashing between the siding and the header and then install the window from the inside pushing the flashing out. And then flash it again...
ddawg16 is online now   Reply With Quote
Old 05-31-2015, 09:09 PM   #9
By the looks of that drywall I would pull it all out, move the window in, then rip wood/plywood to the width needed and trim with casing on the inside.
But that is just me you can do it one of a million ways.
Leave it as is and use thicker brickmould, use the brickmould you have and fill in behhind with something. You get the idea.
Old 05-31-2015, 11:35 PM   #10
Rewards Points: 108
Thanks guys, I used a multi-tool and removed 1/2" of drywall, and got everything flush. I just eyed it and ended up taking a bit too much out, so there is a larger gap than I need, but that is ok, I'll just end up using a lot of caulk. Here is a picture of the outside.
Cheers.
The Following 2 Users Say Thank You to jeffdoesrepairs For This Useful Post:
mae-ling (05-31-2015), Windows on Wash (06-01-2015)
Old 06-01-2015, 01:02 PM   #11
Rewards Points: 172
I gotta be straight with you Jim, that inside trim looks like crap and it's going to get worse if you clean it up with caulk. You should tear off the sheetrock inside trim and do it right in a traditional style.
ChuckF. is offline   Reply With Quote
Old 06-01-2015, 03:12 PM   #12
Rewards Points: 108
It looks much better after it is painted, I just went over it with a hawk and trowel texture, and that is why it looks crappy. I've done this with other windows in the house and it ends up looking great. It is a cool venetian sort of texture style that looks great after some paint. I'll try to post some pictures once the ledges are done and everything is painted so you can see the finished product. Cheers
House on Crawl Space - Sagging Center Beam - Need Advise stevenrossi Building & Construction 9 01-17-2017 11:32 AM
Can you flash replacement windows with existing siding? twobyfour2 Windows and Doors 3 05-31-2011 10:29 PM
Installing nail fin windows - house wrap and t 111 siding DirtDog Remodeling 3 03-17-2011 12:59 AM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 01:18 PM
