Windows Peeling/aluminum ? - Windows and Doors - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-28-2013, 08:03 AM   #16
Rewards Points: 14,278
Since I'm semi retired what I do now is just small jobs I can handle myself.
My next three jobs are to go back and fix DIY wrapping and siding jobs.
Some had 6" pieces of siding with no nails.
No window tape around the doors or windows.
One door did not have the first nail in the J moulding, just caulking to hold it in place.
No Z moulding over windows or sliders.
No utility trim under the windows.
Siding cut to long or nailed to tight.
No house wrap.
Coil stock was installed starting at the top.
All the J mouldings were cut wrong and there's no tab at the top.
Siding and sheathing was run right into the ground.
All this on one house.
Might be one more reason I suggested hiring someone.
bsa_bob (04-01-2013)
Old 04-01-2013, 11:22 AM   #17
bsa_bob
Rewards Points: 150
Originally Posted by Aserviceperson View Post
In my experience if wood trim is not holding paint it could have areas of silicone contamination. Did you get anything on the wood that is perhaps preventing paint from adhering? A pic always helps
Someone here mentioned ..."did you prime the wood first"??????I did not..but I bought Valspar,exterior paint from lowes home imp,. that supposedly has a primer built in to the paint. Is this a new angle to you, or was I to vulnerable to advertisements on primer and paint- all- in- one. Do you see what i'm saying please! let me here it..and thank you bob s
ps all the other o/s paint is staying on good! this is all under 3' overhangs.
bsa_bob is offline   Reply With Quote
Old 04-01-2013, 11:26 AM   #18
bsa_bob
Rewards Points: 150
[QUOTE=joecaption;1147667]Since I'm semi retired what I do now is just small jobs I can handle myself.
No house wrap.
No Joe!!!you pretty well covered the whole enchilada. my garage has plastic siding to close to the ground therefore ..........hacked up to beat the band.by weed whip
How do I get a siding man to come out and not charge me A ton........or even get one to come out for two measley windows . ???????? huh joe!!
Old 04-01-2013, 03:26 PM   #19
bsa_bob
Rewards Points: 150
bump bump
Old 04-01-2013, 03:42 PM   #20
All up to you to make some phone calls.
Someone may be able to work you in if they finish up a job early, get a day were it may or may not rain so they do not need a full crew, Someone may just be slow this time of year.
No way to know unless you call and find out.
No idea what you consider a ton of money.
To do this job right there going to be bringing serveral thousands of dollars in tools and years of know how.
Plus the roll of material that cost them about $80.00.
Small jobs always cost more, got to have the same tools but there's added time to come look at it and set up time.
Old 04-12-2013, 05:38 PM   #21
bsa_bob
Rewards Points: 150
Hi Joe!! i bent some angle up at the local lumber emporium..heh heh FREE- FREE -FREE- it took me 20 minutes[first time on a bender] tin bender that is!cut to length and installed it on both windows.
I was done with them and painted to match the windows . i had an hour in each window. It pays to come here and ask questions!about stuff. When someone says i can't do that ...whatever,.... i usually come out well..Not always!!! but enough to make me smile saving money. again joe thank you for your info bob s---------- Now i have time to work on my 55 chevy project ....AND have extra money for parts!!!yyayy--- aaaah its a good life joe if you don't weaken.. bob s see ya
ps they pretty good too.
The Following User Says Thank You to bsa_bob For This Useful Post:
Windows on Wash (04-12-2013)
Any restitution for VERY late windows? msbriggs Building & Construction 21 10-05-2010 06:25 AM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 12:18 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
