Windows For New Home Construction - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-01-2013, 08:23 PM   #1
Windows for New Home Construction
Our contractor has given us the choice of two window companies: Weather Shield, and MGM Industries. Do any of you know anything about these windows? Which would you recommend? We would like wood window frames inside the house, and either vinyl or aluminum frames on the outside of the house. Is this possible? Which would you recommend, vinyl or aluminum exterior frames, and why? Thanks in advance for your insights.
KG2013 is offline   Reply With Quote
Old 09-01-2013, 09:09 PM   #2
Rewards Points: 13,250
Going to have to go back and add your location to your profile for better reply's. No since in suggesting a brand you can not even get.
Just go to Quick links to edit.
I use mostly Windcor and Simonton windows. Never had a call back from fogging up.
While those clad windows look nice when there new, there a lot more mantaince to keep up with to keep the insides from peeling or rotting from condensation.
Every 10 + year old window I've seen that was clad has needed replacing from the bottom sash rotting or lack of up keep.
Anderson and Pella are two of the worst ones for this. And they will not warranty them.
http://www.complaintsboard.com/compl...a-c208774.html
Old 09-01-2013, 09:42 PM   #3
Sorry about not posting my location on my profile. I'm in Alabama. The link that you have regarding weathershield complaints is pretty discouraging. Thanks for sharing it. Could you explain what you mean by clad windows? Are you referring to the vinyl or aluminum exterior, or are you referring to the wood interior? Thanks again.
Old 09-02-2013, 06:29 AM   #4
Clad mean any wood that's been covered with another material.
If you want that look you may want to check into fiberglass or composite windows.
Have you been checking prices on windows yet?
Hope you have deep pockets of your going to go with anything but standard all vinyl windows.
How a window gets installed is at least important as what brand it is.
An expensive window installed wrong is going to leak, not stay up, fog up.
PS, not a big fan of aluminum clad or framed windows. Over time the finish can fail and if there's not the proper thermal break they can transfer heat and cold.
Old 09-02-2013, 06:43 AM   #5
747
registered
747's Avatar
Rewards Points: 534
Marvin wood interior clad exterior. Never heard of those two company's. If you don't want to spend this much. Look into Simonton new construction windows.
I've given you the best. Then an excellent affordable alternative.
747 is offline   Reply With Quote
Old 09-02-2013, 08:52 AM   #6
Bill Kearney
Rewards Points: 1,174
We went with Marvin windows. They're pricey but they look and work great.
wkearney99 is offline   Reply With Quote
Old 09-03-2013, 03:33 PM   #7
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,768
Neither.
Marvin makes a great window.
If you are not married to the all wood but want a wood look, the Integrity with the real wood interior is a good looking window.
Old 09-04-2013, 06:06 PM   #8
Thanks for all of your input. We've decided to go with the Simonton windows. After your recommendations, we spent a lot of time reading reviews, and talking to installers, and the Simonton seems like the best choice for us. Which series of Simonton's would you recommend? Is the 5050 series okay, or do we need to look at one of their higher end windows? Since the house will be on a lake in N.W. Alabama, we will have a lot of rain, and humidity to contend with. I was wondering if this would make a difference as to which windows to select.
Old 09-05-2013, 04:07 AM   #9
747
registered
747's Avatar
Rewards Points: 534
ProFinish Brickmould 600
The low e argon filled is standard. Plus you have alot of options on interior and exterior colors.
Old 09-16-2013, 06:06 AM   #10
Don't mess with the 5050. Not very sturdy as compared to their other lines.
Need URGENT help with question regarding fixing electrical panel in home asledge Electrical 66 02-22-2013 05:49 PM
windows in home built in 1978 mwcrandell Windows and Doors 5 10-25-2012 02:00 PM
new construction windows in an old house homehobby Windows and Doors 18 08-26-2012 05:02 PM
Waterproofing New Construction Windows In Old Siding chronojosh Building & Construction 4 03-31-2012 12:42 AM
