Windows For My 10 Year Old House - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 02-08-2012, 08:57 PM   #1
Windows for my 10 year old house
Hi,
I am looking to replace my current single pane aluminum windows that allow all of the florida heat into my house .
I cut the sheetrock around the window to get an exact measurement of the window that is their at this time.
My current window is 36"x62" internally from frame to frame and externally 37"x63". I went to lowes to get some prices and the guy was asking me the size and said if i make the window 1/2" smaller from width and height I could save 25.00 per window.
So I tell him to quote me exactly what I have now and do not care to spend the extra couple dollars that could give me a headache later .
So he quotes me for 4 windows and the paper says
frame type(Overall width): Nail fin w/ j Channel(4 3/16" OAW - - 2 9/16" WD)
FRame size width 36"
Frame Size Heigth 62"
So my house has siding upstaris so i will need a nailing fin to nail on the plywood. now I will need 4 more but these are going on masonry. Can I order the same ones for hte masonry side of the house.
N01B4ME is offline   Reply With Quote
Old 02-08-2012, 09:27 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
By masonry do you mean brick?
Your rough openings are the same no matter what the siding, so same windows.
titanoman is offline   Reply With Quote
Old 02-08-2012, 09:34 PM   #3
Yes on brick.
Old 02-08-2012, 09:41 PM   #4
Rewards Points: 13,300
Little more to it than that.
And without any pictures inside and out it's hard to say what you need to order.
Windows are ordered by rough open size. There is no inside and outside measurements used when ordering windows.
You may be better off calling around and having someone else install these.
You order them wrong and there no taking them back.
Old 02-08-2012, 09:47 PM   #5
Home Performance
HomeSealed's Avatar
Rewards Points: 712
It will be very difficult to install a finned window in a brick to brick application. If, otoh, you have trim around the window (between it and the brick), you can just remove that and measure the same way as the others.
Whether or not your exact measurements are correct, that I could not comment on without seeing it in person.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 02-08-2012, 10:01 PM   #6
I cut the sheetrock and measured exactly the existing window. I am talking about the windows with the siding outside. At this point the plywood is against the window so I know I will need to tear the frames out and use the nailing fin on those.
The ones wherethe bricks are at. I had my dad use a chisel to break away the concrete and that window measured exactly the same. So I am assuming that I need to order 4 that go on the siding with a nailing fin and the other 4 that go on the bricks with concrete on the sides will need some kind of face. I just don't know which ones to order for those.
I can get pictures tomorrow when the sun is out. Does anyone know of a local in Pasco FL I could order windows from. If not I have to go through lowes. I did have a compnay come out here and they quoted me 15 grand for 12 windows.
Old 02-08-2012, 10:08 PM   #7
Lowes, Home Depot, Sears will be about double what any local contractor can do it for.
Unless those windows were plated in gold they quoted, or there's something your not telling us that was a rip off.
Old 02-09-2012, 04:15 PM   #8
Well I found and awesopme guy and ordered 12 PGT windows.
Old 02-09-2012, 04:33 PM   #9
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Nice choice. I don't have experience with them personally, but I've heard good things and the performance numbers look good.
www.HomeSealed.com
Old 02-09-2012, 08:54 PM   #10
Thanks I went with the PGT 400 series ....
Old 02-16-2012, 06:22 AM   #11
"It will be very difficult to install a finned window in a brick to brick application. If, otoh, you have trim around the window (between it and the brick), you can just remove that and measure the same way as the others.
Whether or not your exact measurements are correct, that I could not comment on without seeing it in person."
This is a really good point, to fit a window on to a brick on brick surrounding... I wouldn't be surprised if you start getting some guys quoting a higher price, but thats personal experience in England...
Home windows is offline   Reply With Quote
new windows on 30 year old house bobfeather Windows and Doors 2 07-04-2011 03:12 PM
Leaking Vinyl Windows in 7 year old home c3uo Building & Construction 14 04-12-2011 10:02 PM
Installing nail fin windows - house wrap and t 111 siding DirtDog Remodeling 3 03-17-2011 12:59 AM
Any restitution for VERY late windows? msbriggs Building & Construction 21 10-05-2010 07:25 AM
