Windows With Gap - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 11-21-2012, 10:55 AM   #1
Windows with gap
Hello,
my windows have this gap at the top and at the bottom, thus air is coming in and/or escaping. Is their a way I can be fixed?
giannishadj is offline   Reply With Quote
Old 11-21-2012, 11:12 AM   #2
Rewards Points: 12,818
Looks like a really cheap window.
There should have been vinyl strips built into the widow that would have filled in that gap.
Sort of like this picture. Every company has there own design but work like this one.
http://www.bing.com/images/search?q=...+frame+details
Old 11-21-2012, 11:15 AM   #3
Is there a way to get it fixed?
Old 11-21-2012, 11:33 AM   #4
Not that I've ever heard of.
I'm sure there's going to be more replys so someone may have some suggestions so hang in there.
Old 11-21-2012, 12:25 PM   #5
One thing that would help is to buy some foam in a roll, cut it to length and stick it in the whole.
Measure before buying. It's sold in the winterizing area in any hardware, or box store.
Old 11-21-2012, 05:00 PM   #6
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Can you take another pic from a little bit farther away? Something doesn't look quite right there... Even cheapo windows should not have a gaping hole like that.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 11-22-2012, 01:58 AM   #7
If that's a slider window, then there should be a piece of weather strip in that space like this
Measure the gap and you can purchase this stuff at about any hardware store.
spotco2 is offline   Reply With Quote
The Following User Says Thank You to spotco2 For This Useful Post:
joecaption (11-22-2012)
Old 11-26-2012, 09:12 AM   #8
Do you guys know where can I find something like this?
Old 11-26-2012, 03:07 PM   #9
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Can I assume that is the piece that is missing in the previous pic? ... I don't think that fin seal pictured above will quite do the job.
Is there anything on the window that indicates the manufacturer? If so, contact them. If not, try a place like Strybuc. They are a company that sells all different types of window hardware. If you still have no luck, you might just need to fabricate something to fit in that space.
www.HomeSealed.com
Old 11-27-2012, 12:58 AM   #10
I cannot seem to find anything like this on the market. However I have noticed that most of the windows in my country have this gap! It is unbelievable how crappy these window people are and if you are as useless as I am on spotting such things then this is what happens to you!
Anyway. I need to do something because the cold is unbelievable, too much air passes through and I want a permanent fix. I searched the internet for this thing but don't have a clue of how its called. If I don't find it what else can I use?
Homesealed thanks for the advice but unfortunately we don't have Strybuc.
Old 11-27-2012, 01:01 AM   #11
Thanks mate. It is an option I guess. Will this stop the air from flowing in? I mean not being something solid do the hair on the strip still prevent the air from flowing in?
Old 11-27-2012, 07:25 AM   #12
Home Performance
HomeSealed's Avatar
Rewards Points: 710
That fin seal is not going to fix your problem... Search the web for Strybuc. You can purchase parts mail order. You can either search their catalog, or speak to someone over the phone that may be able to point you in the right direction. Even if you don't know the proper term for that piece, the approximate size and location/function of it should suffice.
www.HomeSealed.com
Pella Windows - Serious Frost Issue snowman72 General DIY Discussions 22 07-08-2011 01:39 AM
Any restitution for VERY late windows? msbriggs Building & Construction 21 10-05-2010 07:25 AM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 01:18 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 07:06 PM
