Window Wells & Grading - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-08-2013, 09:15 PM   #1
GBunny
Rewards Points: 71
I would like to enlarge a window and put in a window well. The ground slopes in the backyard and after a heavy rain, water pools in the middle of the yard a bit. Is there anything I need to worry about with regard to grading.
I know 2 people that have window wells and they both had flooding in their basement. Is there a relationship with window wells and flooding?
GBunny is offline   Reply With Quote
Old 08-09-2013, 08:56 AM   #2
Rewards Points: 13,296
Sure looks like you could add fill and raise that grade at least 6" to get the water to run away from the house toward the yard.
If the well does not have the proper drainage in the bottom of the pit, grade does not run away from it, foundation wall was not waterproofed before back filling, waters going to get in.
Old 08-09-2013, 09:08 AM   #3
DIY staff
Rewards Points: 7,174
Yep----the new window well will need a drain----
Does your house have perimeter drains and a sump pump?
If not, your new larger window will require some trenching and a sump pit-
That part might be more work than adding a window and a window well-
Old 08-14-2013, 09:39 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,884
Grading, gravel, and a properly installed vertical drain leg into your weeping system is pivotal.
I would add a battery back up to the list as well if your sump runs during rain storms.
A good sump system a must but there is not replacement for proper grading and moisture direction.
Water Coming in Through Basement Window Wells koz123 Building & Construction 5 08-09-2011 06:15 PM
Installing a Replacement Vinyl window with brick mold jlatulippe Carpentry 4 06-23-2011 03:05 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 07:37 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 11:47 AM
