Window Trim - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 10-27-2012, 09:22 AM   #1
Window Trim
Should the drywall be removed on the inside of the window to install jamb extensions? or can I go over the drywall?
path5604 is offline   Reply With Quote
Old 10-27-2012, 12:13 PM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Generally speaking drywall removal is preferred and will yield a better result, but there are some circumstances where it can be left in and look okay. Post up a pic if you would like some more specific feedback.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is online now   Reply With Quote
Old 10-27-2012, 04:07 PM   #3
most windows aren't wide enough for the jambs to sit over the
drywall. you get a much better job taking the drywall and corner bead
off first esp if the corner bead isn't straight like a lot of them.
it also give you a chance to see if they insulated or foamed around the windows.
Window trim over existing T-111? J Howard Remodeling 2 07-24-2012 11:49 AM
crown molding meets window trim sonofthetonsured Carpentry 13 03-19-2011 01:33 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Arched top window trim jelly Carpentry 5 07-05-2008 04:38 PM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-14-2005 12:59 AM
