-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Window Trim (http://www.diychatroom.com/f104/window-trim-161291/)
path5604 10-27-2012 09:22 AM
Window Trim
Should the drywall be removed on the inside of the window to install jamb extensions? or can I go over the drywall?
HomeSealed 10-27-2012 12:13 PM
Generally speaking drywall removal is preferred and will yield a better result, but there are some circumstances where it can be left in and look okay. Post up a pic if you would like some more specific feedback. :)
DannyT 10-27-2012 04:07 PM
most windows aren't wide enough for the jambs to sit over the
drywall. you get a much better job taking the drywall and corner bead
off first esp if the corner bead isn't straight like a lot of them.
it also give you a chance to see if they insulated or foamed around the windows.
