Window Sweat - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 10-06-2012, 09:53 AM   #1
Window Sweat
I have one sweating window in the house. These windows were installed originally when the house was built in 1998. It could be 98 degrees with 15% humidity or as high as 100 DEGREES WITH NO HUMIDITY. It could be between 15 to 50 degrees during the winter time. It does not matter. Basically ALL YEAR long this window sweats. Thought about a heat gun to eliminate the sweat. I believe it is between the two panes of glass. Any help??
cbgtrth is offline   Reply With Quote
Old 10-06-2012, 10:01 AM   #2
the Musigician
DangerMouse's Avatar
If it's between the two panes, then the seal is broken. You may want to see if you can remove the sash and replace just that, or the whole window, depending upon ease. Wood? Vinyl? What material and mfg.? Photos always help here.
DM
Old 10-06-2012, 10:17 AM   #3
The window is vinyl. Manufacturer?? Your guess is as good as mine, No label anywhere on the window. I am just going to call it a cheap manufacturer window.
Old 10-06-2012, 10:20 AM   #4
the Musigician
Nothing on the glass?
DM
Old 10-06-2012, 01:14 PM   #5
Correct. Nothing ON the glass. The sweat is between the glass
Old 10-06-2012, 01:54 PM   #6
the Musigician
I understand. Usually, the mnfg. name is etched or printed in a lower corner on the pane itself.
...or possibly a sticker inside the frame. You may be able to find it with the window opened.
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
Windows on Wash (10-07-2012)
Old 10-07-2012, 09:09 AM   #7
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,250
Seal failure it is.
How old is the window? Could be covered under warranty. Like DM said, look for an etching on the glass or a sticker on the side of the sash or inside the head jamb pocket.
how to deal with a window in a shower MLMIB Kitchen & Bath Remodeling 9 09-12-2012 08:41 AM
New replacement window problems iminaquagmire Windows and Doors 7 11-11-2011 11:56 PM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 05:00 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
