-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Window Sweat (http://www.diychatroom.com/f104/window-sweat-159139/)
cbgtrth 10-06-2012 10:53 AM
Window Sweat
I have one sweating window in the house. These windows were installed originally when the house was built in 1998. It could be 98 degrees with 15% humidity or as high as 100 DEGREES WITH NO HUMIDITY. It could be between 15 to 50 degrees during the winter time. It does not matter. Basically ALL YEAR long this window sweats. Thought about a heat gun to eliminate the sweat. I believe it is between the two panes of glass. Any help??
DangerMouse 10-06-2012 11:01 AM
If it's between the two panes, then the seal is broken. You may want to see if you can remove the sash and replace just that, or the whole window, depending upon ease. Wood? Vinyl? What material and mfg.? Photos always help here.
DM
cbgtrth 10-06-2012 11:17 AM
The window is vinyl. Manufacturer?? Your guess is as good as mine, No label anywhere on the window. I am just going to call it a cheap manufacturer window.
DangerMouse 10-06-2012 11:20 AM
Nothing on the glass?
DM
cbgtrth 10-06-2012 02:14 PM
Correct. Nothing ON the glass. The sweat is between the glass
DangerMouse 10-06-2012 02:54 PM
I understand. Usually, the mnfg. name is etched or printed in a lower corner on the pane itself.
...or possibly a sticker inside the frame. You may be able to find it with the window opened.
DM
Windows on Wash 10-07-2012 10:09 AM
+1
Seal failure it is.
How old is the window? Could be covered under warranty. Like DM said, look for an etching on the glass or a sticker on the side of the sash or inside the head jamb pocket.
