-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   window stucco (http://www.diychatroom.com/f104/window-stucco-143565/)
Restyle 05-12-2012 07:24 PM
1 Attachment(s)
I removed a door and filled the lower space with cinderblocks. Then I added a window to the upper part. The window that I had custom made was a bit smaller than the opening. So now I'm a little stuck at the stucco part. Do I need to use an agent to stick the stucco to the painted wall? And do I need to use lath corners around the opening. I'll attach a pic. Thanks
Attachment 50712. Image May be rotated. The dark part is a new stucco coat under the window
Jkslate 05-15-2012 07:33 PM
I'm not sure exactly what I'm seeing.
Is this an exterior stucco wall? If so, then this window needs to be completely removed and reinstalled correctly with moist stop/jiffy seal and correctly lathing techniques, not to mention a new construction fin.
If this is interior and you're talking about plaster, then depending on the plaster depth you can just patch it with drywall and mud/imperial.
Please clarify some more :thumbsup:
Windows on Wash 05-16-2012 08:44 AM
+1 Jkslates feedback.
If that is the exterior...that is 100% incorrect.
