-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Window stop question (http://www.diychatroom.com/f104/window-stop-question-189498/)
detroittigerfan 10-30-2013 11:53 AM
Hi There,
I have a question. I am considering a replacement window. My confusion is the end stops that the back of the window rests against. Are those part of the actual window or are they part of the rough framing?
HomeSealed 10-30-2013 03:00 PM
Are you talking about the stops that the storm sits against, and the upper (outer) sash ride against? Those are blind stops and they are part of the original window frame.
detroittigerfan 10-30-2013 03:46 PM
If im doing a replacement window am I removing just the double sashes that are there or am I removing the entire window? I currently have a double hung vinyl window and am confused about what needs to be removed for a replacement window?
joecaption 10-30-2013 03:56 PM
Now were confused. If you already have a vinyl new construction window how are you going to install a replacement window?
Most I've seen the jams and tracks are all one piece.
Got some pictures.
Replacement windows are mainly for replacing old style wood windows not vinyl.
detroittigerfan 10-30-2013 04:46 PM
Got some pictures.
My house is brick sided so how could they be new construction since there would be no room for the nailing flange? How else can you install a window in brick without using a replacement window?
joecaption 10-30-2013 05:07 PM
We have no idea what type window you have now, there was no mention of brick in your first post and no picture.
I use what's called a flat jamb window, it will have a built in window sill that's angled on the outside that sits on the soldiered brick on the outside. A replacement window is just a flat sided frame.
Most windows installed in brick walls used brick moulding on the outside to trim them out and act like a stop which could be left in place if replacing the window unless the caulking is such that there stuck so bad you can not get them out.
Windows on Wash 10-30-2013 05:34 PM
If a wood window, just the stop (for access) and then the sashes.
detroittigerfan 10-30-2013 06:34 PM
Can you use new const. windows for brick sided houses or would it need to be a replacement window?
joecaption 10-30-2013 07:37 PM
Still waiting for a picture, inside and out, your there where not. No one can see what you have now so how do we suggest how to do the job?
HomeSealed 10-30-2013 07:48 PM
A pic would be very helpful. What we need to know is if you have an existing new construction vinyl window set in the RO, or if you have old wood frames that already have vinyl replacements in them.
joecaption 10-30-2013 07:51 PM
You can buy new construction windows with built in brick moulding that get installed from the outside. No seams, nothing to leak.
detroittigerfan 10-30-2013 09:32 PM
Ok, since they have brick moulding I assume the windows is fastened through the side jambs? Just curious though is it possible to install a flanged window in a brick sided house though since you have the brick and small amount of air space covering the area where the nailing flange would be.
HomeSealed 10-31-2013 03:11 PM
Possible, yes. Easy, not typically.
windowrepairguy 11-02-2013 01:57 PM
You're just asking for leaks. First, I would really either let a professional do the install or have a local window repair & installation company come out and give you a consultation. You're plugging a huge hole in your house when you install a window. It's critical to get everything right the first time or you're asking for trouble. Leaks turn into mold which turns into rot which turns into ants and more mold and lots of money to repair. Window installation is not a joke and should be taken extremely seriously. Proper adhesives to the substrates you are sealing, installing proper backer rod and insulation, squaring, plumbing all have major impacts on the final outcome of the installation. You get what you pay for with windows and the installation process. Pay for a quality install now or pay much more for major repairs to your walls, ceilings, floors and whatever else later! Trust me on this. I've seen it all too often.
http://www.windowrepairguy.com/ROW_W...ir.htmlhttp://
windowrepairguy 11-02-2013 02:01 PM
Unless of course you have done this before.
