Window Sills - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 11-17-2011, 08:05 AM   #1
Ejm
Window sills
I recently framed a new window in an existing 2x4 wall. I want to install an interior window sill, but I do not have framing to rest it on. Does anyone have any thoughts?
Ejm is offline   Reply With Quote
Old 11-17-2011, 08:11 AM   #2
Rewards Points: 2,238
Hi! "Ejm"
Post a picture?!
rossfingal
rossfingal is offline   Reply With Quote
Old 11-17-2011, 08:32 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,928
Window casing around the surround and the stool can be tacked into that.
Old 11-17-2011, 08:40 AM   #4
Ejm
Originally Posted by rossfingal
Hi! "Ejm"
Post a picture?!
rossfingal
Ok. I will send tonight
Old 11-17-2011, 08:57 AM   #5
Ejm
So I should make up the trim, nail it all together and then hang on the wall?
Old 11-17-2011, 09:26 AM   #6
kwikfishron's Avatar
Rewards Points: 186
Then whatís the window sitting on?
Your framing should look like this, if it doesnít then you need to correct it before you trim the window.
The only exception to this pic is that a solid header may not be necessary if the wall is not load bearing.
kwikfishron is online now   Reply With Quote
Old 11-17-2011, 12:02 PM   #7
Home Performance
HomeSealed's Avatar
Rewards Points: 712
That would be pretty difficult... It sounds like you are talking about a stool board (the interior trim "sill") as WoW mentioned. If you put on an apron (an upside down piece of casing under the stool), the stool can rest on that and be tacked down... That is if I am understanding your question correctly.
..Is the window installed? Did you pull it in flush with the drywall? If so, a better option would be to "picture frame" the casing on all four sides and have no stool. Otherwise, if you are trying to match other windows, you can fake one the way I mentioned above.
As mentioned, a pic would be great.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 11-17-2011, 04:09 PM   #8
In a little over my head
Rewards Points: 706
I had windows that were installed flush with the drywall. The installers offered to "picture frame" them. I wanted a sill (stool), so I told them not to bother. I made molding out of 1x3 to match my (metal) door casings. For the apron, I routed the "inside" profile on a 1x4 edge and turned the moulding upside down (like HomeSealed said) Then, I bullnosed a piece of 1x for the stool and attached it at a right angle to the apron with my biscuit joiner and glue. Nailed the apron to the wall. Then installed the sides and top molding with mitered top corners. Came out great, and the glued and biscuited stool have been plenty strong for all the knick-knacks and decorations my wife needs on 'em.
If I remember correctly, the Home Depot book (Trim 123?) was quite helpful.
ratherbefishing is offline   Reply With Quote
The Following User Says Thank You to ratherbefishing For This Useful Post:
HomeSealed (11-17-2011)
Old 11-17-2011, 04:18 PM   #9
Ejm
Old 11-17-2011, 05:58 PM   #10
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Sounds like a nice job!
www.HomeSealed.com
The Following User Says Thank You to HomeSealed For This Useful Post:
ratherbefishing (11-18-2011)
Old 11-17-2011, 07:56 PM   #11
Ejm
The widow is framed properly. Here are some pic to help explain.
Old 11-17-2011, 07:57 PM   #12
Ejm
I like the idea about putting the apron on first. I will try that
Old 11-17-2011, 07:58 PM   #13
Ejm
Thanks for all the good suggestions
Old 11-18-2011, 08:10 AM   #14
Good Luck!
Post up some pictures when you are done.
replacing window sills denemante Building & Construction 1 09-29-2010 03:59 PM
Building Window Sills - HELP!!! lgallo Carpentry 18 03-06-2010 02:58 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
PVC window sills thegal59 Carpentry 9 09-20-2009 09:25 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
