Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 10-15-2012, 02:38 PM   #1
Window seals on the inside!
I hope this is a good place to ask questions about windows! On the inside of where the window would meet the window frame, I can push on the window and see where there is a crack and it makes it bigger when I push..now I can't tell if it is drywall cracking or what it is but I am curious if it would be smart to put some kind of caulking material all along the inside in order to ensure that there is a seal between the too. Any tips let me know! Thanks a lot!
Zach
mckain87 is offline   Reply With Quote
Old 10-15-2012, 02:42 PM   #2
And without a picture and the full info where confused to.
Wood window, vinyl, replacment window?
Is the gap where the window sits in the track or the trim on the face of the jamb.
woodworkbykirk (10-15-2012)
Old 10-15-2012, 05:52 PM   #3
Again..I will get a picture and get back with you. Thanks.
Old 10-15-2012, 06:02 PM   #4
sdsester's Avatar
Sounds like the entire window frame has come loose or was never nailed properly.
sdsester is offline   Reply With Quote
Old 10-16-2012, 11:07 AM   #5
Herr are a view different pictures of around the windows. Im wondering if I should put caulk around...
Old 10-16-2012, 11:52 AM   #6
Exterior Construction
Windows on Wash's Avatar
That is a sealant interface.
Tape off the drywall with painters tape to get a nice clean line and caulk with a good interior latex if you require it to be paintable.
Old 10-16-2012, 08:40 PM   #7
if those cracks get bigger when you push out on the window = the window is not fastened well enough to the structure. and i don't see caulk making it stronger to any real degree.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
Windows on Wash (10-17-2012)
Old 10-17-2012, 09:11 AM   #8
Fix'n it,
Many windows have pretty minimal wall thickness and can/will deflect at that location if you push on them. He could put 40 screws in each jamb and it still might move at that location if he/she pushed on it right.
I agree that you should check it out but there are just some products that move regardless.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Fix'n it (10-17-2012)
Old 10-17-2012, 09:17 AM   #9
I'd remove what old caulking I could and just apply a new coat of quaility latex caulking prime and paint over it.
Quaility caulking does not say Painters caulk on the lable. It says paintable.
$3.00 a tube caulking is not the same as the one that cost $5.00 +.
Old 10-17-2012, 09:18 PM   #10
Originally Posted by Windows on Wash View Post
Fix'n it,
ahh, i gotcha. the frame flex's, not moves.
Old 10-19-2012, 09:46 AM   #11
AHH, SPANS!!!
Use a utility razor knife and cut out the old caulk that is pulling loose and replace with new caulk. you could just re caulk but you will be re caulking again in 6 months if you do not take out the old caulk.
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
joecaption (10-19-2012)
Crown molding inside bay window Dieter Carpentry 7 10-03-2010 07:23 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 07:37 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Can I replace a window from the inside? KE2KB Carpentry 14 04-28-2009 04:08 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 09:39 PM
