Window Sealant - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-25-2013, 07:32 AM   #1
Telescopist's Avatar
Rewards Points: 91
Window sealant
I just purchased 9 Simonton 50-50 vinyl windows to replace some ancient double hungs. I am heading to Lowes. Any recommendations on caulk to use between window and outside stop would be appreciated.
Telescopist is offline   Reply With Quote
Old 07-25-2013, 07:35 AM   #2
Rewards Points: 14,312
I use Alex 230 and never had any problems.
Old 07-25-2013, 07:44 AM   #3
Rewards Points: 91
Thanks. Box stores like Lowes carry it?
Old 07-25-2013, 08:01 AM   #4
Sure do.
It's not the cheapest but it's a 50 year caulk.
Telescopist (07-25-2013)
Old 07-25-2013, 08:09 AM   #5
Home Remodeler
Rewards Points: 164
Agree with Joe, it has some silicone in it that should help it stick to the vinyl. It is paintable also.
mikey48 is offline   Reply With Quote
The Following User Says Thank You to mikey48 For This Useful Post:
Old 07-25-2013, 02:38 PM   #6
Sure do.
It's like most things, you get what you pay for.
TreverS is offline   Reply With Quote
Old 07-25-2013, 02:57 PM   #7
Home Performance
HomeSealed's Avatar
Rewards Points: 712
I use quad on most everything except the interior due to the VOC's. They do have a water based interior caulk called H2U however that is very good... Solar seal, Vulkem, and Geocell are good as well, as would be pure silicone if this will be in an area that won't ever see paint.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Alum horizontal plane window is leaking. butwhydoitalk2u General DIY Discussions 1 11-01-2011 07:00 AM
Best sealant for window frame darsunt Building & Construction 11 10-20-2011 09:02 AM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 05:00 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
