Window Screens And Gnats - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-18-2013, 12:49 AM   #1
Rewards Points: 208
Window Screens and Gnats
Are there window screens that will keep out gnats and tiny green gnats?
Scully is offline   Reply With Quote
Old 08-18-2013, 01:48 AM   #2
Rewards Points: 6,652
Yes, but they will be a very fine grid, and would have to be washed out more often, to get the dust off them. What part of Wisconsin are you in again Scully?
Old 08-18-2013, 01:52 AM   #3
Rewards Points: 208
what are these fine grids called? do they obstruct light?
SE wisconsin
Old 08-18-2013, 07:54 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
Some of the manufacturers are offering them as a standard now.
Are you looking at replacement windows or re-screening some existing units?
There is no real brand name out there for specific gnat proof screens. Many of the producers private label the stuff now.
If you are retrofitting an existing screen, I would ask them for a high visibility but tight mesh.
Old 08-18-2013, 08:14 AM   #5
Rewards Points: 2,646
Yes.
Windows screen mesh size is measured by numbers such as 16-18 (that's wires per inch, first number in the horizontal direction, next number in the vertical dimension). So the bigger the number, the finer the screen. When you go to the hardware store, look for the specification on the label (it may or might not be on the label). 20-20 (sometimes called no-see-um screening) is the finest that I have seen, but even this stuff is a little hard to find. But 20-20 is probably what you are looking for. Keep looking -- you will find some. See below link as example of sizes available:
http://www.grainger.com/Grainger/wwg...rue&sst=subset
SPS-1 is offline   Reply With Quote
Old 08-18-2013, 12:39 PM   #6
Check with your local Ace Hardware about rescreening the window screens, with the material you want, to see what they would charge per unit.
Old 06-02-2016, 12:18 AM   #7
Rewards Points: 26
Re: Window Screens and Gnats
Gnat... Some of our displays required fix so I took them to the shop and they changed the information, but since placing the displays support a short time ago, we've had headache levels of these insects getting in when we have the ms windows start. Occurred again tonight; at least they are interested in the mild, so I can usually convert off all the lighting in one space except one, and they will all move to the roof above that mild. Then I get them with the machine.
razibpaul126 is offline   Reply With Quote
gnats? boman47k Pest Control 0 10-24-2011 03:51 PM
