Window Screens - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-31-2012, 11:03 AM   #1
window screens
How to re-install widow screens back into vinyl channels.
2 compression springs are on the side of the screen but I still cant clear the opposite channel flange after compressing the springs.
sambar is offline   Reply With Quote
Old 05-31-2012, 01:27 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,218
You might be trying to put it in the wrong channel or have the wrong screen on the wrong window. It is pretty easy to do though and you should have any issues.
Old 05-31-2012, 09:59 PM   #3
Replacement Window Advice
Window Advisor's Avatar
Yeah, should be pretty straight forward, if you still can get them in a picture of it may help with some suggestions.
Window Advisor is offline   Reply With Quote
Old 05-31-2012, 10:54 PM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 712
+1... I have also seen instances where the frame was "over-shimmed", causing it to be very difficult to both operate the sashes and the screens... Some more detail on the situation would help.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Andersen Window Screens jte1130 Windows and Doors 2 04-28-2008 02:23 PM
Removing/replacing window screens gt2003 Building & Construction 5 09-21-2005 05:51 AM
